Confusing ID # on 413 motor home engine. #974588
04/16/11 08:53 PM
04/16/11 08:53 PM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
Here is what I know for sure about the engine. It is a 413 out of a motor home. I cannot positively id the year of manufacture. There are no casting #s or date on the right side of the block like I am accustomed to seeing on other big blocks.
The #s on the stamping pad are:
FT413
3 17
Can anyone ID this engine?
Thanks for any help.
Roger
Re: Confusing ID # on 413 motor home engine. [Re: rjones] #974589
04/17/11 11:43 AM
04/17/11 11:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I would say it is a 70 .
There is not casting date ?? That is odd .
Re: Confusing ID # on 413 motor home engine. [Re: JohnRR] #974590
04/17/11 01:38 PM
04/17/11 01:38 PM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
This engine is complete from carb to oil pan with most of the accessories still on it. There is probably a casting # on it somewhere, I just did not want to strip the engine to locate it. It has no casting # in the usual place you see them on 400s and 440s. It should be decodable from the id stamped on the id boss but I have not been able to google anything on it that seems reliable. Some say the F stand for year 70 but the 413 I believe was discontinued before this date. Some say the T stands for truck engine others say the T stand for year model 63. Nothing consistent.
Roger
Roger
Re: Confusing ID # on 413 motor home engine. [Re: rjones] #974591
04/17/11 03:07 PM
04/17/11 03:07 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had a 73 Dodge chassis Champion body motor home with the 413. I think production ended in 71 or 72 for that engine..., with chassis in stock at the body builders for a year or two after that.. None of the Just in Time BS they use today..
Re: Confusing ID # on 413 motor home engine. [Re: rjones] #974592
04/17/11 03:10 PM
04/17/11 03:10 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
NO BIG casting #'s on this block that I am aware of ... just a small casting date.
...and for you that miss my shift key ...TALK TO the cRaZy OnE north of the border !
