Page 2 of 3 1 2 3
Re: oil pump not priming [Re: express] #974457
04/17/11 12:33 PM
04/17/11 12:33 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
Did you prime the pump itself? Fill it with oil or take the cover off & pack with vaseline. I would also take the pump apart if all else checks out, I have heard horror stories of the pump full of shavings out of the box.
Yes, I also checked the clearances. I am going to seperate the tranny and check the plugs. I am sure that it will resolve very soon.
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: oil pump not priming [Re: siggie30] #974458
04/18/11 11:34 AM
04/18/11 11:34 AM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
I am still stumped. I am thinking that there may be gaskets for the pump, but I do not have any or recall seeing any. Is there in fact a gasket that seats between the pump and the cap, and is there an o-ring that seats on the shaft? If so, then this would be the culpret.
Also, to confirm, I have cup plugs installed under the cam retainer(X2). The internal plug by the oil pump drive, the 2 rear external plugs, the plug under the oil filter, and the cap plug under the rear main. If there are more than that then they are all in.
Re: oil pump not priming [Re: siggie30] #974459
04/18/11 01:41 PM
04/18/11 01:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't remember the factory installing a gasket between the pump and the cap , but someone mentioned it above so I think the aftermarket deemed one necessary at some point , can't answer the o ring on the shaft either but that doesn't jog anything in my memory either .
It has to be on the pickup side, it must be pulling air which is why it will not prime. Maybe the pickup tube ofthe pump housing is cracked ? Did you have the pump in the oil during your bucket test ?
Re: oil pump not priming [Re: siggie30] #974460
04/18/11 01:48 PM
04/18/11 01:48 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
My Melling HV pump for my 5.9 Magnum motor came with a gasket that gets installed between the cap and the pump. I have purchased many oil pumps over the years and sometimes they come with a gasket and other times they don't.
Re: oil pump not priming [Re: AtomicDog] #974461
04/18/11 01:56 PM
04/18/11 01:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You don't need a gasket, that's not the problem. It's on the suction side.
Re: oil pump not priming [Re: Challenger 1] #974462
04/18/11 08:23 PM
04/18/11 08:23 PM
Post it when you find it, inquiring minds want to know. I'm dying to hear what it was
Re: oil pump not priming [Re: siggie30] #974463
04/19/11 03:30 AM
04/19/11 03:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
did you use a set of main studs or aftermarket main bolts If so look very closely at the pump to stud or bolt clearance They can, and do, hold the pump from seating onto the main cap, don't ask me how I know that
Re: oil pump not priming [Re: RapidRobert] #974464
04/19/11 08:55 AM
04/19/11 08:55 AM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
bypass mini cup plug not driven up high enough. good there? time to take a look at the pump/rear main cap/pickup
I am curious about this cup plug under the main. When I installed it, I basically installed it flush or slightly recessed. Gathering info about this, I learned that on Chevy engines, the plug is driven pretty deep. Someone here mentioned that there is a ridge to stop the plug at some point. How deep should it really be? And would this prevent oil flow?
Re: oil pump not priming [Re: siggie30] #974465
04/19/11 09:12 AM
04/19/11 09:12 AM
want it here to divert oil out to the filter rather than it going straight up to the horizontle main gallery
Re: oil pump not priming [Re: RapidRobert] #974466
04/19/11 09:33 AM
04/19/11 09:33 AM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
Is there a stop? Is this why it is not priming?
Re: oil pump not priming [Re: siggie30] #974467
04/19/11 10:57 AM
04/19/11 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If that picture is accurate it sounds like you don't have the plug in far enough and the oil is not going past the main cap and the pump is just dumping the oil back into the pan thru relief valve It would appear .
Re: oil pump not priming [Re: JohnRR] #974468
04/19/11 12:51 PM
04/19/11 12:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Someone said something naughty ...
Re: oil pump not priming [Re: JohnRR] #974469
04/19/11 04:48 PM
04/19/11 04:48 PM
scratchnfotraction Offline
I cant recall what it is..but there is a measurment that you can check with a piece of wire down the oil pressure sender passage to check that the plug "is" there and at the right position
around 7" IIRC
most times its over looked and not installed after tanking the block and cleaning the oil galleys
Re: oil pump not priming [Re: scratchnfotraction] #974470
04/19/11 06:56 PM
04/19/11 06:56 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
I took the cap off and started driving the cup plug in. There is a passage about 2" or so in. I have not finished assembly to check yet, but will post when I finish. Thanks guys.
Edit: Yep, there was a gusher from the top of the block after pressing the plug in.
Re: oil pump not priming [Re: RapidRobert] #974471
04/19/11 08:26 PM
04/19/11 08:26 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
This was the correct diagnosis. Thanks Robert. To add insult to injury, after the sensor was reinstalled, the oil filter started to spew oil, so I think the adapter fitting is not tight or the interior plug needs attention. I am sure the plug is there, but an easy fix comparatively.
Re: oil pump not priming [Re: siggie30] #974472
04/19/11 09:55 PM
04/19/11 09:55 PM
adaptor nipple needs torqued or the big outer gasket didnt seal or both
make sure your fliter plate is not bent in the middle and not pulling the outside edge in tight enuff..you did use a gasket on the block to plate seal correct?
one good mod is to drill 4 more holes in the plate for a total of 8 holes for the filter
Re: oil pump not priming [Re: scratchnfotraction] #974473
04/20/11 07:34 PM
04/20/11 07:34 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
My filter plate had 6 holes. I did have the gasket, BUT it was not torqed down. My engine is running smoothly now and no oil leaks. Again, thanks to everyone for helping out.
Re: oil pump not priming [Re: siggie30] #974474
05/30/11 01:16 AM
05/30/11 01:16 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I'm dealing with the same issue on my 360/410 right now. Poured in five quarts and it won't pressurize (turning clockwise)
Removed the oil filter and adapter and found it bone dry.
Stuck a rod down the sending unit hole and hit the plug right where it's supposed to be.
I double checked to make sure all galley plugs were installed when I got the block back, so I'm certain that's not the problem.
Reusing this pump from my 340. Looked brand new and worked fine in the old motor.
Running a Kevko pan and pickup. Pick-up depth is right where is supposed to be.
Looking like I need to drop the pan to see what's going on.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: oil pump not priming [Re: 471Magnum] #974475
05/30/11 01:55 AM
05/30/11 01:55 AM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
check the pickup a little closer. I pulled mine and found a crack above the oil level. Swapped out the pickup and it came right up. If not try packing the oil pump with assembly lube.
Re: oil pump not priming [Re: Theorio1025] #974476
05/30/11 03:36 PM
05/30/11 03:36 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I think my problem might actually be with the priming shaft. It was made from a big block intermediate shaft and the diameter is not reduced at the base like it is on a SB shaft. It's not dropping into the pump drive.
I've got a couple SB shafts I can use to make a new one.
Stay tuned.
-Jim
Page 2 of 3 1 2 3
