1970 383 distributor casting numbers #974370
04/16/11 01:58 PM
04/16/11 01:58 PM
NoVa
E
ebodyseast Offline OP
E
NoVa
Can someone check what casting numbers are found inside original 1970 383 2 & 4bbl distributor housings - once shaft and mounting plate are removed. Want to distinguish difference in casting numbers between a 1970 383 2bbl housing and a 383 4bbl. I'm fairly certain that 2875302/308 are the two casting numbers and need someone to verify what the 2bbl number is. Parts book shows the '70 440HP housing is identical to 383 4bbl. Anybody have original one that's apart? Thanks Moparts!
Re: 1970 383 distributor casting numbers [Re: ebodyseast] #974371
04/17/11 11:41 AM
04/17/11 11:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This ought to be good
