EDDY HEADS
#974315
04/16/11 01:11 PM
04/16/11 01:11 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i have a set of eddy heads decked fro 88cc to 64cc.any one know how much to cut the intake. thanks
WAXER
Re: EDDY HEADS
[Re: Jeepmon]
#974318
04/16/11 04:24 PM
04/16/11 04:24 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
To my thinking you would need to know what the stock height outer bolt bosses on the Eddys are; they might be 1.00" like stock Mopar heads.
Then measure your heads to find what was cut, for example .090" and multiply by 1.23 X .090"=.1107". Or, another way 9 [.090 ÷ .010] X .0123"=.1107" off the intake.
Re: EDDY HEADS
[Re: QWK_ENUF]
#974319
04/16/11 04:30 PM
04/16/11 04:30 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Typically its about .005-.006 per cc.
I usually take a minimum of 1:1 of intake per deck milling, and I think 64 Post is correct at around .011/.012 is usually the real number off the intake.So .010 off the deck, .011-.012 off the intake. Thats a lot of cutting on those heads. How come?
RIP Monte Smith
Re: EDDY HEADS
[Re: QWK_ENUF]
#974324
04/18/11 01:10 AM
04/18/11 01:10 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
i have a set of eddy heads decked from 88cc to 64cc.any one know how much to cut the intake. thanks
The 88cc heads were the Open chambered heads. So you can mill less off the face per cc loss compared to the 84cc closed chamber head.
From my estimates your Eddy 88cc open chamber heads were cut to around a .100 mill.
The correct geometry math is .100 off the flat, .123 off the intake.
With a proper .123 off the intake face, the intake vallay pan rail will need a xx amount of mill too.
I have never followed or used the correct geometry math myself. Below .040 shaves,sometimes none of the above needs to be addressed.
My Question is, Did you cut these heads yourself this much or did you pick them up, on the cheap off of someone else who did.
Either/or, no one cuts the flats this much without taking something off the intake side. Most machinests will stamp the heads with said mill measurements.
