69 B body ignition switch lamp replacement #974312
04/16/11 01:01 PM
04/16/11 01:01 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
Anyone know how to get this bulb out? I can access it through the ashtray area but what holds it in. I had the whole dash apart when I rebuilt it I can for the life of me remember how it went in.
Re: 69 B body ignition switch lamp replacement [Re: torkrules] #974313
04/16/11 01:16 PM
04/16/11 01:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
bulb holder is sandwitched between the switch and the dashframe and requires switch removal to take said holder out.
I don't remember if the bulb is removal without taking the switch/holder out or not
Re: 69 B body ignition switch lamp replacement [Re: gtx6970] #974314
04/16/11 01:39 PM
04/16/11 01:39 PM
I'm neurotic
I'm neurotic
Didn't have to pull the switch out but thanks it did point me in the right direction (found out because I did pull the switch out). Once I had the holder in my hands I figured out that the bulb socket just pulls out of the holder.
