Page 1 of 3 1 2 3
What will it dyno! (engine dyno) #974150
04/16/11 05:37 AM
04/16/11 05:37 AM
U.S.
moparniac Offline OP
U.S.
Prolly about a monthish out from being done with my new bullet but wanted to see what your guesss are! First time ever to go to dyno also so any tips to be prepared would be helpful also
Special thanks goes out to Competition Wedge on here for hooking me up with some new bottom end parts! Also like my new Superformance gasket set also thanks to the guys who sent some helpful pm's
New Combo(pump gas baby )
574CI World Aluminum Block
4.500*4.505
7.100 rod
Indy 440-1 CNC 345's from Best Machine
2.25*1.81 ferreas backcut
k motion k 1000H springs
Indy dominator pattern intake milled and ported
Good size custom comp 3/4 roller 112 wide and in at 108 from 112
TD rockers 1.65
Milodon GD
ATI balancer
Melling HV pump
windage tray
milodon static pickup
CVR 55GPM electric waterpump
11.89 to 1 compression
Dynamic compression ratio is 8.84:1
Dynamic cranking pressure is 180.84 PSI.
(calculated via wallace @ 0 altitude)
.051 quench
Diamond pistons cut deeper and rolled edges
Total seal rings
steel top .028
napier 2nd .032
Pro Systems SV1 (1212CFM)
TTI/Proparts 2-2 1/8th ceramic coated headers
MSD goods
tried to be detailed.... prolly forgot something though!
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974151
04/16/11 06:34 AM
04/16/11 06:34 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Me first!!
875Hp @ 7000 rpm (ish)
Re: What will it dyno! (engine dyno) [Re: moparniac] #974152
04/16/11 08:15 AM
04/16/11 08:15 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
WOW
Its hard for me to guess
Oh well, the 3/4 cam should put you over the 900 mark.
Re: What will it dyno! (engine dyno) [Re: 340RICK] #974153
04/16/11 08:36 AM
04/16/11 08:36 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
807 @ 7100 RPM, 733 ft/lbs @ 5400 RPM I tried to be more specific but the 3/4 cam threw me a curve
Re: What will it dyno! (engine dyno) [Re: Bigcube] #974154
04/16/11 08:56 AM
04/16/11 08:56 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
775hp 750tq . what the hell is a 3/4 cam?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: What will it dyno! (engine dyno) [Re: Bigcube] #974155
04/16/11 09:00 AM
04/16/11 09:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Just a seat of the pants guess. A little over 800ish but at a slightly lower rpm than BigCube's guess...6900 peak HP RPM. Let me leave you with well-wishes and good luck.
Re: What will it dyno! (engine dyno) [Re: HardcoreB] #974156
04/16/11 09:16 AM
04/16/11 09:16 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
3/4 would be .750
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: What will it dyno! (engine dyno) [Re: StripeHOG] #974157
04/16/11 09:28 AM
04/16/11 09:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That's a 3/4 cam plus a 1.65 rocker so really its like a 7/8 cam. The only problem I see is the compression. Aluminum block and aluminum heads love compression. I think you will be really happy with your power level but left a lot on the table. To bad E85 is such a hassle finding in Pa. I look forward to seeing some passes at PRP.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What will it dyno! (engine dyno) [Re: pittsburghracer] #974158
04/16/11 09:40 AM
04/16/11 09:40 AM
U.S.
U.S.
your right on the cam im not into "BIG" compression setups cause im to cheap to pay for race gas and drive streets mostly
Id like to see 800hp/725tq outta the combo
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974159
04/16/11 09:43 AM
04/16/11 09:43 AM
NC
440Jim Offline
440Jim  Offline
NC
Especially important when putting together a pump gas combo is the compression ratio and cam specs. I like your CR choice. What is the duration of that cam?
However, even a cam with "too much" duration for the CR will work OK with that much CID.
It should be close to your target even with that 0.680" lift cam (.75/1.65*1.5). 574 CID does wonders.
Re: What will it dyno! (engine dyno) [Re: moparniac] #974160
04/16/11 09:49 AM
04/16/11 09:49 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Good luck Sledgie! Sounds like a real stout piece. Should be able to meet your goals easily.
Randy
Re: What will it dyno! (engine dyno) [Re: Dartin] #974161
04/16/11 09:54 AM
04/16/11 09:54 AM
U.S.
U.S.
Randy
thx! all im down to is lifters and pushrods to finish up
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974162
04/16/11 09:56 AM
04/16/11 09:56 AM
gregsdart Offline
gregsdart  Offline
I'll take a stab at 810 hp at 6600 rpm. To drop compression that far, the cam must be pretty wild, say 282 intake dur @ .050?
Re: What will it dyno! (engine dyno) [Re: Dartin] #974163
04/16/11 09:59 AM
04/16/11 09:59 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Come on Sledgie.... at least tell us when the intake closes..... 3/4 cam
Re: What will it dyno! (engine dyno) [Re: moparniac] #974164
04/16/11 10:05 AM
04/16/11 10:05 AM
PA.
"Little"John
"Little"John
PA.
What flow numbers did Pete get out of your 440-1's. Didn't you loan that carb to another member and if so how did it work for them?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What will it dyno! (engine dyno) [Re: emarine01] #974165
04/16/11 10:06 AM
04/16/11 10:06 AM
U.S.
U.S.
OK 73
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974166
04/16/11 10:08 AM
04/16/11 10:08 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Is the 73 @ 112 or 108?
Re: What will it dyno! (engine dyno) [Re: moparniac] #974167
04/16/11 10:09 AM
04/16/11 10:09 AM
gregsdart Offline
gregsdart  Offline
Are we supposed to guess tQ and Hp with the juice running
Re: What will it dyno! (engine dyno) [Re: gregsdart] #974168
04/16/11 10:16 AM
04/16/11 10:16 AM
U.S.
U.S.
naaaaaaaa! I just wanna hit a 9 NA on motor only and pump gas/radial tires! just always been my goal! after that its time to mess with the N2O
I did put on a good set of DA shocks for this year also! better brakes even so the car should be lighter also and ive been dieting as well
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: gregsdart] #974169
04/16/11 10:17 AM
04/16/11 10:17 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A quick question on quench..... Small blocks run .040 max.... is it the same for larger cube engines?
Page 1 of 3 1 2 3
