TTi or Hedman Hustlers? #974080
04/16/11 12:39 AM
04/16/11 12:39 AM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
I Currently have Dougs on my 414 stroker in my '74 Duster, but they aren't letting it live up to it's full potential. It's doing 7.17 in the 1/8th right now, but I'm sure it can get better. The heads flow 300 (verified by 2 reputable shops) with 2.055/1.65 valves. Cam has 257*@.050 and just over .600 net lift at the valve. The exhaust ports on the heads are larger than the header tubes, so I KNOW the headers are a restriction (1-5/8 tubes). So now I'm considering some bigger headers. A couple of people have told me not to get the TTi 1-3/4. I'm looking at either the 1-7/8 TTi's, or the Hedman Hustlers. The hedmans have straight 1-7/8, or 1-7/8 stepped to 2". So should I get:
1) TTi 1-7/8 (non step)
2) Hedman 1-7/8 (non step)
3) Hedman 1-7/8 to 2" step
4) Other.
Not a big difference in price between the Hedmans and TTi's.
Thanks,
Re: TTi or Hedman Hustlers? [Re: 64physhy] #974081
04/16/11 12:48 AM
04/16/11 12:48 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I know the Hustler Big blocks are fenderwell style. The have some issue's but are ok for race only deal where you have no real need to turn the tires much LOL
But I see no reason to run fender well headers for a small block car. The TTI's I have run were very well made.
Raised Port Indy head RB
and early B 426 Hemi
They fit like a glove.
Re: TTi or Hedman Hustlers? [Re: 64physhy] #974082
04/16/11 01:21 AM
04/16/11 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ask a few questions to the manufacturers... whats the
primary length and the collector length... with the
cam I dont see it being a high reving engine so I wouldnt
bother with the step headers .... you will most likely
need a primary about 33" and a 3.750 dia collector
with it being about 17" long... these numbers should
be CLOSE .... if you want to PM me I can run the
engine through my header program
Re: TTi or Hedman Hustlers? [Re: 64physhy] #974083
04/16/11 07:12 AM
04/16/11 07:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have the 1 7/8" with a 3 1/2" collector Hustlers on my Dart and love them. Only ine tube goes through the fenderwell on each side. I've had TTIs and the Hedmans are a ton easier to install.
What oil pan are you running? The Hedmans don't work well with a pan that has kick outs.
Re: TTi or Hedman Hustlers? [Re: justinp61] #974084
04/16/11 01:56 PM
04/16/11 01:56 PM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
I have a Charlies pan. It doesn't kick out. So far, it seems that most I've spoken with agree on the Hedmans. The 1-7/8 with the 3 1/2 collector is one of the sets I'm considering. I don't mind cutting the inner fender for a tube.
Re: TTi or Hedman Hustlers? [Re: 64physhy] #974085
04/16/11 08:19 PM
04/16/11 08:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hedman... I've used a bunch thru the years and they all fit nice. and the price is nice
Coming soon!!!!
Re: TTi or Hedman Hustlers? [Re: Mr.Yuck] #974086
04/16/11 08:45 PM
04/16/11 08:45 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
One thing to keep in mind with the TTI headers is,though they fit nice,they make comprimises in performance to get them too fit.I have Hedman 1 7/8 headers on my Challenger with a small block,and one tube on each side still goes out of the fenderwell.I think the main reason is to get all the tubes to fit in a way that does not include sharp bends as soon as they exit the flange.Look at some TTI headers and you will see a lot of tight bends right off the head,but they do fit the chassis nice.
Keith
Re: TTi or Hedman Hustlers? [Re: Dunnuck Racing] #974087
04/16/11 09:07 PM
04/16/11 09:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have both sets for sale 1 7/8 TTI and headmans.350 for either set.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: TTi or Hedman Hustlers? [Re: 1967dartgt] #974088
04/20/11 10:46 PM
04/20/11 10:46 PM
ca usa
dusterboy15 Offline
dusterboy15  Offline
ca usa
im interested in the TTI!!!
Re: TTi or Hedman Hustlers? [Re: 1967dartgt] #974089
04/21/11 02:38 AM
04/21/11 02:38 AM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
Got the pics of the hedmans?
Re: TTi or Hedman Hustlers? [Re: 64physhy] #974090
04/21/11 08:34 PM
04/21/11 08:34 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
small block tti's.....
talk to locomotion or myron, they run stock eliminator and would know what makes the best power
Re: TTi or Hedman Hustlers? [Re: nss guy] #974091
04/21/11 08:46 PM
04/21/11 08:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
Locomotion is Myron
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: TTi or Hedman Hustlers? [Re: Triple Threat] #974092
04/21/11 10:44 PM
04/21/11 10:44 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
my fault,
I was thinking of micheal beard duct tape
Re: TTi or Hedman Hustlers? [Re: nss guy] #974093
04/22/11 10:22 PM
04/22/11 10:22 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
1 7/8 to 2" is where i'd go with my indy headed motor i have now,not sure if you'll do better w a larger header on ur set up ,my tti 1 5/8 were good on my old eddy headed set up
