68 Charger motor mount ??? #974067
04/15/11 11:25 PM
04/15/11 11:25 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Does a 400 and a 360 use the same motor mounts if not where can you buy them at?
Re: 68 Charger motor mount ??? [Re: KY Charger] #974068
04/15/11 11:37 PM
04/15/11 11:37 PM
AndyF Offline
AndyF  Offline
Schumacher should have everything you need.
Re: 68 Charger motor mount ??? [Re: AndyF] #974069
04/16/11 04:54 PM
04/16/11 04:54 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
they use the same rubber motor mount insulators, same k-frame, that is it. the steel engine mounting brackets which bolt to the ears of the actual engine block are different, 360 uses 1 set and 383/400/440 big blocks use a completely different set. if you need pictures of them let me know , i can show you what you need.
Re: 68 Charger motor mount ??? [Re: Joesixpack] #974070
04/18/11 07:09 PM
04/18/11 07:09 PM
Bowling Green, KY
K
K
Bowling Green, KY
Where can u buy them at
Re: 68 Charger motor mount ??? [Re: KY Charger] #974071
04/19/11 04:05 PM
04/19/11 04:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
WHICH 1?
