Re: Stupid me or Stupid spring tester????
[Re: 451Mopar]
#973985
04/16/11 09:53 AM
04/16/11 09:53 AM
Posts: 16,934 NC
440Jim
NC
Are they suppose to be tested with a retainer>?
Yes x2
![](/ubbthreads/images/graemlins/iagree.gif) Just be sure to measure the compressed height of the outer spring from the retainer/spring interface, not the top of the retainer. I can't see over 100 lbs change however from just that.
[Re: ragingram]
#973986
04/16/11 11:45 AM
04/16/11 11:45 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Dont use a retainer, but as mentioned, a washer spacer. Most steps of the retainers are from .080-.120, with the most common racing types being .100ish. If you use a retainer you will be adding more that the actual installed height. You want to use a spacer just for the inner spring. You will see a quite different reading I suspect.
RIP Monte Smith
[Re: ragingram]
#973990
04/16/11 06:02 PM
04/16/11 06:02 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do you know anybody with a traditional spring checker that you could use to compare?
[Re: John_Kunkel]
#973991
04/16/11 07:16 PM
04/16/11 07:16 PM
CompWedgeEngines
Syracuse,NY
That is the logical thing to do. I bet you'll see a difference.A calibration spring would tell a lot also.
RIP Monte Smith
[Re: rebel]
#973993
04/16/11 08:06 PM
04/16/11 08:06 PM
John_Kunkel
Rio Linda, CA
There's an old saying...."A man with a watch knows what time it is, a man with two watches is never sure".
Same goes for just about every measuring device, I've got a half-dozen tire pressure gauges and............
