Re: I need to buy new tires for my trailer.??
[Re: wmwalden]
#973666
04/15/11 12:50 PM
04/15/11 12:50 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
What year trailer? Are the sidewalls cracked? Trailer tires should be good for 7 years if kept properly inflated. Longer if kept shaded from the sun. I'm not an expert it's just my worth.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: wmwalden]
#973670
04/15/11 02:37 PM
04/15/11 02:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Go to a true trailer tire with the highest rating you can find or afford... being a 15" you are limited some but you should be able to find E rated... I went with a Goodyear trailer tire... but there are plenty of choices.... stay away from Carlisle
[Re: MR_P_BODY]
#973671
04/15/11 03:12 PM
04/15/11 03:12 PM
Challenger 1
Cincinnati, Ohio
Firm believer in Goodyear trailer tires. Start with ST in the size.
Too bad you have 15" on your 24'. It needs 16" wheels for that size trailer.
Did you know Goodyear recomends 10psi over what the pressure should be for speeds over 65 mph. Everyone goes over 65 at least for a little while like when passing.
My 15" tires on my open trailer say 50 psi and have run them at 60 psi, 17K miles last sumer and 18K in 2009 without any problems, none.
I have the wheels off of it right now doing the bearings and they look great after 2 summers and 35K miles.
Stick 10 pounds of air in em over what the sidewalll says and have a good trip.
[Re: Challenger 1]
#973672
04/15/11 03:23 PM
04/15/11 03:23 PM
Challenger 1
Cincinnati, Ohio
I also ran 16" Goodyears on my 49' enclosed, ran over 100k miles with that trailer, went though 2 sets of 6 on it and NEVER had a flat, never. Always checked the pressure before every trip, trailer fenders are expensive on a Gold Rush trailer. Low Pressure and CURBS is what causes tires to fail. So I hope you can see why I like American made Goodyears.
[Re: imfixinmopars426]
#973674
04/15/11 04:33 PM
04/15/11 04:33 PM
Posts: 5,894 Florida
Locomotion
also! lol
FYI, I had a good, never used 16" E rated spare for my 26' Pace that I kept in the trailer or in a garage. When I did finally put it on after about 8 years, the tread peeled off after less than 2000 miles! Just because it looks good doesn't mean it is. There is a way to interpret tire code dates, but I don't know how or where to find it off hand.
[Re: Locomotion]
#973680
04/17/11 12:24 AM
04/17/11 12:24 AM
Posts: 394 md
wicked
md
also! lol
Not impressed with the carlisle's that replaced the Duro's that came on my trailer. They seemed sized small for the listed tire size, and not holding up near as well
