What about this rockers for BB any good? #973656
04/15/11 12:28 PM
04/15/11 12:28 PM
Denmark
Dart of Denmark Offline OP
Denmark
Re: What about this rockers for BB any good? [Re: Dart of Denmark] #973657
04/15/11 01:52 PM
04/15/11 01:52 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I called the number... they are bushed not roller bearings. I like that in a cheap rocker
Man told me they are procomp
74 dart sport 440 www.Csucarbs.com
Re: What about this rockers for BB any good? [Re: shoebox] #973658
04/15/11 05:40 PM
04/15/11 05:40 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
That is an excellent price! Unfortunately, the low price makes me suspicious. On the other hansd I have had great luck with cheap parts. The rockers I had worked fine,but I didn't work them to hard. I say go for it.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: What about this rockers for BB any good? [Re: Dave_S] #973659
04/16/11 10:24 AM
04/16/11 10:24 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
If you run a roller I wouldn't use them.
Have talked to several guy's that had them break with roller springs.
Re: What about this rockers for BB any good? [Re: supercomp] #973660
04/16/11 06:11 PM
04/16/11 06:11 PM
Denmark
Denmark
Have roller with 707 lift and springs with 260lbs seat pressure. Now i have indyrockers the black one. Have been fine for 65 runs with 7400 rpm on the line.But will upgrade to somthing better!! Any ideas?
Re: What about this rockers for BB any good? [Re: Dart of Denmark] #973661
04/17/11 09:44 AM
04/17/11 09:44 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I only use T&D or Jesel on everything. Pro comps are no better then Indy's. Harland Sharp are also good.
Re: What about this rockers for BB any good? [Re: Dart of Denmark] #973662
04/17/11 06:00 PM
04/17/11 06:00 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I've beat the snot out of that type (Indy) of rocker going 8.90 and now have the same rocker on my street motor. Don't restrict the oil flow, keep the oil holes down-pointed at the crank and you will be fine.
0.02
8.30's @3400 lbs
Re: What about this rockers for BB any good? [Re: Mike Swann] #973663
04/17/11 07:31 PM
04/17/11 07:31 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
They look great for $159.00 ......
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: What about this rockers for BB any good? [Re: chryco] #973664
04/17/11 08:00 PM
04/17/11 08:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
KMJ also has some stainless roller rockers, about twice the price; anyone have experience with them?
I remember at a PRI show a few years ago, some of the budget aluminum rockers I saw there had a lot of roughness in the way the rollers turned.
