Page 4 of 5 1 2 3 4 5
Re: Pinion Angle - here we go.... [Re: 493_DART] #973525
05/09/11 06:27 PM
05/09/11 06:27 PM
tboomer Offline
tboomer  Offline
Go to Steves shop...It is not going to rain!! It is only 90* there!!
Re: Pinion Angle - here we go.... [Re: tboomer] #973526
05/09/11 06:48 PM
05/09/11 06:48 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
weatherman said rain for 2 days---no clouds down here . car is put away .
Re: Pinion Angle - here we go.... [Re: 493_DART] #973527
05/09/11 07:01 PM
05/09/11 07:01 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
well, i give up. Im taking the car to a pro
measured again today:
1 method says 5 degrees down (wolfe)
another method says 8 degrees down (trans yoke /pinion yoke)
either way ive got too much angle
Re: Pinion Angle - here we go.... [Re: 493_DART] #973528
05/09/11 07:03 PM
05/09/11 07:03 PM
tboomer Offline
tboomer  Offline
The shop is open another 1/2 hour...Load up and go!!
Re: Pinion Angle - here we go.... [Re: Sport440] #973529
05/09/11 10:00 PM
05/09/11 10:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
[In MR.Pbodies car, he built his engine/tranny driveline paralell to the pinion. He and anyone else who does the same can accurately set the pinion angle off the Shaft.
People with Unmolested drivetrains can set the pinion angle off the shaft and still not have problems. Though the accuracy of the true pinion angle wont be known. As long as your getting a negative angle reading between the two of 3* to 5* or so. The U joints will do thier job and you wont notice anything most likely.
With a modified car such as yours, I think one can see you wouldnt want to measure it off the Shaft.
Your current measurements between the shaft and pinion give you a neg/-14*
Your current measurements between the tranny centerline and pinion give you a neg/-9*
Both sets of numbers are telling you, that your pinion angle is to far negative. If your measurments are "correct"""
Re: Pinion Angle - here we go.... [Re: 493_DART] #973530
05/09/11 10:02 PM
05/09/11 10:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
well, either way ive got too much angle
Re: Pinion Angle - here we go.... [Re: DoctorDiff] #973531
05/09/11 10:26 PM
05/09/11 10:26 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Probably stupid questions compared to yours but I was wondering:
I am going to install the Hotchkis Leaf springs, does it change significantly the amount of pinion angle I should try to get?
What about snubbers setting for street cars, would you adjust them to become in contact at 1 degree? 0 degree?
Also, I've read somewhere that when you remove a driveshaft from the transmission you have to put it back at the same place in order to be in phase... I really don't understand this, is in it how the driveshaft is welded together that determine the phasing and not how you clock the yoke in the transmission?
Re: Pinion Angle - here we go.... [Re: 74_360_Cuda] #973532
05/10/11 01:48 AM
05/10/11 01:48 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
BEHOLD !!!! My top notch MS Paint skills !!
Here is how i measured today :
#1
Re: Pinion Angle - here we go.... [Re: 493_DART] #973533
05/10/11 01:49 AM
05/10/11 01:49 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
#2
Re: Pinion Angle - here we go.... [Re: 493_DART] #973534
05/10/11 01:51 AM
05/10/11 01:51 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
SO,,,,,,,,
Im at 8 degrees down ......
agree ?
Re: Pinion Angle - here we go.... [Re: 493_DART] #973535
05/10/11 01:52 AM
05/10/11 01:52 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would put the angle finder on the machined surfaces of the diff. yoke and the transmission yoke.
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973536
05/10/11 01:54 AM
05/10/11 01:54 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Kevin I think you have finally found your true calling
Re: Pinion Angle - here we go.... [Re: 493_DART] #973537
05/10/11 02:02 AM
05/10/11 02:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you go by the trans/diff way its 8*... which is
too much
EDIT
most of the cast yokes have a tapper cast into the
area you show the protractor....you would have a truer
reading on the front surface where the bolts mount
Re: Pinion Angle - here we go.... [Re: 493_DART] #973538
05/10/11 04:15 AM
05/10/11 04:15 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
SO,,,,,,,,
agree ?
Yes, From these numbers, your 8* down from tranny to pinion.
Re: Pinion Angle - here we go.... [Re: Al_Alguire] #973539
05/10/11 04:52 AM
05/10/11 04:52 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Al -- are you making fun of my amazing artwork ???? !!! ???
HOW DARE YOU !!
Re: Pinion Angle - here we go.... [Re: MR_P_BODY] #973540
05/10/11 04:58 AM
05/10/11 04:58 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
too much
EDIT
dammmm !!! another variable thrown into this .......
so now i need to pull the shaft and start over .... ?
Mr. P - how much taper are we talking about ?? would you say 1 degree? 2 degrees ?
we need a smiley figure that puts a gun in his mouth and blows his head off........
Re: Pinion Angle - here we go.... [Re: 493_DART] #973541
05/10/11 07:59 AM
05/10/11 07:59 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
most stock mopars i have checked, the trans is pointing down. and your 727 is really ugly
Re: Pinion Angle - here we go.... [Re: 493_DART] #973542
05/10/11 11:09 AM
05/10/11 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont really know... I never measured it but you
can see it.... just trying to warn you... you can
measure off the U-joint cap if you want... I made
up a quick little tool for measuring off the cap but
you can use a socket that fits and put your inclineometer
on the socket... you will notice that one side is
the pinion and the other is the drive shaft, just
take the reading at the bottom(closest to the ground)
Re: Pinion Angle - here we go.... [Re: sixpackgut] #973543
05/11/11 12:59 AM
05/11/11 12:59 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Im very hurt by your comments .....sitting in a pool of my own tears ........
Re: Pinion Angle - here we go.... [Re: sixpackgut] #973544
05/11/11 01:08 AM
05/11/11 01:08 AM
Renton Washington
Triple Threat Offline
Renton Washington
Core shift ....
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
