Page 2 of 5 1 2 3 4 5
Re: Pinion Angle - here we go.... [Re: patrick] #973485
04/15/11 02:24 PM
04/15/11 02:24 PM
gregsdart Offline
gregsdart  Offline
(Why did I let myself get drawn into this mess?)
Motor/transmission center line in relation to pinion center line = proper way to measure. Not too difficult, some don't get it. Some will argue till the moon turns to swiss cheese. physics says this is the proper way to cancel change in speed due to an angled joint. Run the joints ninety degrees to each other, all is good if the trans and diff are close to parallel. Some angle is needed to properly keep the joints lubed and keep the needles from flattening due to being at the same spot all the time. If the engine/trans measurement didn't matter, then the diff angle wouldn't either. Run one too far out of alignment, you get broken trans parts. I will try and load a photo.
If the trans is pointing down and the diff is pointing down, add them. If either is going a different direction, subtract the smaller angle from the larger. If both are pointing up, fix em.
Re: Pinion Angle - here we go.... [Re: gregsdart] #973486
04/15/11 02:32 PM
04/15/11 02:32 PM
gregsdart Offline
gregsdart  Offline
2nd gear planetary that broke when speed reached about 50 mph.
Twice, didn't catch the pinion angle change due to axle turning on the tubes till the second time!
Re: Pinion Angle - here we go.... [Re: gregsdart] #973487
04/15/11 03:45 PM
04/15/11 03:45 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I gid mine as the rosslers chart but you are supposed to set it with your weight in the drivers seat.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Pinion Angle - here we go.... [Re: patrick] #973488
04/15/11 03:53 PM
04/15/11 03:53 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
trans seal - measured vertically 88 degrees (2?) UP .
(you can go off the balancer if you can get on it for this measurement also)
pinion yoke (u joint cap) 5 degrees DOWN
so ... what is my pinion angle ?
-3
I would say 7* pinion angle. This is why if your transmission was 0* just for sake of trying to make things easy, then you raise the trans 2* you have added angle if you lower it 2* you would have 3* pinion angle. This is why I always use the drive shaft and the pinion yoke, the math is easier.
bzzzt! do not pass go, do not collect $200.
pinion angle is the angle of the tranny output shaft relative to the pinion shaft. if the tranny is 0, to have 0 pinion angle, the pinion has to be 0. if the tranny is 2 deg. nose up (higher in rear than front), the pinion has to be 2 degrees nose down (higher in the rear than the front) for pinion angle. his pinion shaft is 3 degrees nose down more than the 0 point, so -3 (3 degrees nose down) is correct
I had to put it on paper but you are right -3* is your pinion angle. So can I have my $200.00 dollars now?
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973489
04/15/11 08:44 PM
04/15/11 08:44 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok ...
so far we have 2 guys at -3
that rossler chart doesnt show me how to figure MY angles into it. I just dont get it . If YOU "get" the rossler chart--- figure my pinion angle with it and let me know what you get
Re: Pinion Angle - here we go.... [Re: 493_DART] #973490
04/15/11 09:31 PM
04/15/11 09:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
ok ...
First theres a problem with your info.
The two guys that gave you -3 are Correct When using your 2* UP Tranny angle and 5* Down Pinion angle.
For the Tranny angle you have a single mesurement of 2* UP! But for the Pinion Angle you have 3 Seperate Down measurements.
5* , 9* , and 10*
With the 5* measurement being taken off the "Yoke Cap"?? I take that to mean you measured off the universal joints cap seated in the pinion yoke.
Im going to guess/assume that, that measurement is a error. And the correct measurement is closer to 9* or 10*
But , I will list All 3 pinion angles for the above numbers with a 2 * +/Up Tranny angle.
Tranny--------Pinion------Pinion angle--
2*Up----------5* Down-------=/ -3* Down
2*Up----------9* Down-------=/ -7* Down
2*Up---------10* Down-------=/ -8* Down
Any of the Above Tranny/Pinion numbers if Correct will Represent your "True" "Pinion Angle" between tranny and pinion centerline.
EDIT; With your shaft 4* down and pinion 10* down that = a 14* Driveshaft/Pinion angle, but a Actual 8* Tranny/Pinion angle relationship with the tranny being 2* up. Confusing I know!
The Ujoint by "Physics" is designed to work best under load at a Parallel driveline angle. But lets not Forget its name. "Universal Joint", It peforms best within Parallel plane parameters but will work beyond those perimeters as well.
Re: Pinion Angle - here we go.... [Re: Sport440] #973491
04/15/11 11:27 PM
04/15/11 11:27 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks Sport ---
Now , we also have the crowd that uses the pinion measurement and the D shaft measurement....will their results be the same numbers ?
Re: Pinion Angle - here we go.... [Re: patrick] #973492
04/15/11 11:37 PM
04/15/11 11:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ok Ok....Red....
Re: Pinion Angle - here we go.... [Re: 493_DART] #973493
04/16/11 12:29 AM
04/16/11 12:29 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
thanks Sport ---
No, You only gave One set of numbers between the pinion and the driveshaft.
Those were 4* down Shaft and 10* Down Pinion, witch would give you a "Driveshaft /Pinion angle of 14*
I will Edit my post to include that for a perspective.
Re: Pinion Angle - here we go.... [Re: Sport440] #973494
04/16/11 02:02 AM
04/16/11 02:02 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks Sport ---
OK, here is what i meant ---
there are people who measure the shaft and the pinion.
your method is the Trans and the pinion. correct?
here is what i mean :
skip to about 2:00
http://www.youtube.com/watch?v=i8FNgaNqS8s
notice this guy doesnt include any trans angle
Re: Pinion Angle - here we go.... [Re: Al_Alguire] #973495
04/16/11 02:06 AM
04/16/11 02:06 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Ok Ok....Red....
you are not helping Al.....
Re: Pinion Angle - here we go.... [Re: 493_DART] #973496
04/16/11 02:11 AM
04/16/11 02:11 AM
Canada
CrAzYMoPaRGuY Offline
Canada
A few of the responses are kinda funny.
Set your operating angle. Use your trans angle to set your operating angle, like the Rossler chart or 100 other charts.
Once you have your operating angle set, then set your pinion angle, like the Rossler chart or 100 other charts.
It's the terminology that gets everyone all up in the air, some state operating/pinion angle, some think both are combined into the same thing.
CrAzYMoPaRGuY
Re: Pinion Angle - here we go.... [Re: CrAzYMoPaRGuY] #973497
04/16/11 02:25 AM
04/16/11 02:25 AM
Carson City, Nevada
Carson City, Nevada
BLUE...
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973498
04/16/11 03:34 AM
04/16/11 03:34 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
just completely forget about the driveshaft measurement!
Mopar Performance
Re: Pinion Angle - here we go.... [Re: moparniac] #973499
04/16/11 03:34 AM
04/16/11 03:34 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Pinion Angle - here we go.... [Re: moparniac] #973500
04/16/11 04:01 AM
04/16/11 04:01 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
you see why im asking? some swear by the shaft----some dont use the shaft in the equation !
Re: Pinion Angle - here we go.... [Re: CrAzYMoPaRGuY] #973501
04/16/11 04:04 AM
04/16/11 04:04 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I have the Rossler. Please post the other 99 charts. Or how about this --- 5 other charts?
this is the meaning of my thread
Re: Pinion Angle - here we go.... [Re: 493_DART] #973502
04/16/11 04:20 AM
04/16/11 04:20 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
yea I used to think that way also! however dr diff the guy who messes with rears for a living says to go off the tranny and rear so I use that all the time now and forget the rest... less headache that way and it works! for the record I am at -4 right now...
Mopar Performance
Re: Pinion Angle - here we go.... [Re: moparniac] #973503
04/16/11 09:23 AM
04/16/11 09:23 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I went off the rossler chart and mine is 6 degrees down on SS springs but i think you might need a little less with caltracs.
Mick
best 60ft 1.36
Re: Pinion Angle - here we go.... [Re: 493_DART] #973504
04/16/11 10:02 AM
04/16/11 10:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont set the working angle first you could have
WAY to much angle and still be right if you go off
the trans... for instance IF your trans is 12" above
the pinion the angle could be correct but the joints
would be in bind
