Re: Pinion Angle - here we go....
[Re: patrick]
#973485
04/15/11 02:24 PM
04/15/11 02:24 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
(Why did I let myself get drawn into this mess?) Motor/transmission center line in relation to pinion center line = proper way to measure. Not too difficult, some don't get it. Some will argue till the moon turns to swiss cheese. physics says this is the proper way to cancel change in speed due to an angled joint. Run the joints ninety degrees to each other, all is good if the trans and diff are close to parallel. Some angle is needed to properly keep the joints lubed and keep the needles from flattening due to being at the same spot all the time. If the engine/trans measurement didn't matter, then the diff angle wouldn't either. Run one too far out of alignment, you get broken trans parts. I will try and load a photo. If the trans is pointing down and the diff is pointing down, add them. If either is going a different direction, subtract the smaller angle from the larger. If both are pointing up, fix em.
[Re: gregsdart]
#973487
04/15/11 03:45 PM
04/15/11 03:45 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I gid mine as the rosslers chart but you are supposed to set it with your weight in the drivers seat.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: patrick]
#973488
04/15/11 03:53 PM
04/15/11 03:53 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
trans seal - measured vertically 88 degrees (2?) UP . (you can go off the balancer if you can get on it for this measurement also)
pinion yoke (u joint cap) 5 degrees DOWN
so ... what is my pinion angle ?
-3
I would say 7* pinion angle. This is why if your transmission was 0* just for sake of trying to make things easy, then you raise the trans 2* you have added angle if you lower it 2* you would have 3* pinion angle. This is why I always use the drive shaft and the pinion yoke, the math is easier.
bzzzt! do not pass go, do not collect $200.
pinion angle is the angle of the tranny output shaft relative to the pinion shaft. if the tranny is 0, to have 0 pinion angle, the pinion has to be 0. if the tranny is 2 deg. nose up (higher in rear than front), the pinion has to be 2 degrees nose down (higher in the rear than the front) for pinion angle. his pinion shaft is 3 degrees nose down more than the 0 point, so -3 (3 degrees nose down) is correct
I had to put it on paper but you are right -3* is your pinion angle. So can I have my $200.00 dollars now?
[Re: Biginchmopar]
#973489
04/15/11 08:44 PM
04/15/11 08:44 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
ok ... so far we have 2 guys at -3 that rossler chart doesnt show me how to figure MY angles into it. I just dont get it . If YOU "get" the rossler chart--- figure my pinion angle with it and let me know what you get
[Re: 493_DART]
#973490
04/15/11 09:31 PM
04/15/11 09:31 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
ok ...
First theres a problem with your info.
The two guys that gave you -3 are Correct When using your 2* UP Tranny angle and 5* Down Pinion angle.
For the Tranny angle you have a single mesurement of 2* UP! But for the Pinion Angle you have 3 Seperate Down measurements.
5* , 9* , and 10*
With the 5* measurement being taken off the "Yoke Cap"?? I take that to mean you measured off the universal joints cap seated in the pinion yoke.
Im going to guess/assume that, that measurement is a error. And the correct measurement is closer to 9* or 10*
But , I will list All 3 pinion angles for the above numbers with a 2 * +/Up Tranny angle.
Tranny--------Pinion------Pinion angle--
2*Up----------5* Down-------=/ -3* Down
2*Up----------9* Down-------=/ -7* Down
2*Up---------10* Down-------=/ -8* Down
Any of the Above Tranny/Pinion numbers if Correct will Represent your "True" "Pinion Angle" between tranny and pinion centerline.
EDIT; With your shaft 4* down and pinion 10* down that = a 14* Driveshaft/Pinion angle, but a Actual 8* Tranny/Pinion angle relationship with the tranny being 2* up. Confusing I know!
The Ujoint by "Physics" is designed to work best under load at a Parallel driveline angle. But lets not Forget its name. "Universal Joint", It peforms best within Parallel plane parameters but will work beyond those perimeters as well.
[Re: 493_DART]
#973493
04/16/11 12:29 AM
04/16/11 12:29 AM
Sport440
Canton, Ohio
thanks Sport ---
Now , we also have the crowd that uses the pinion measurement and the D shaft measurement....will their results be the same numbers ?
No, You only gave One set of numbers between the pinion and the driveshaft.
Those were 4* down Shaft and 10* Down Pinion, witch would give you a "Driveshaft /Pinion angle of 14*
I will Edit my post to include that for a perspective.
[Re: Sport440]
#973494
04/16/11 02:02 AM
04/16/11 02:02 AM
493_DART
Worst Weather USA
thanks Sport ---
OK, here is what i meant ---
there are people who measure the shaft and the pinion.
your method is the Trans and the pinion. correct?
here is what i mean :
skip to about 2:00
http://www.youtube.com/watch?v=i8FNgaNqS8s
notice this guy doesnt include any trans angle
[Re: 493_DART]
#973496
04/16/11 02:11 AM
04/16/11 02:11 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
A few of the responses are kinda funny. Set your operating angle. Use your trans angle to set your operating angle, like the Rossler chart or 100 other charts. Once you have your operating angle set, then set your pinion angle, like the Rossler chart or 100 other charts. It's the terminology that gets everyone all up in the air, some state operating/pinion angle, some think both are combined into the same thing.
CrAzYMoPaRGuY
[Re: moparniac]
#973500
04/16/11 04:01 AM
04/16/11 04:01 AM
493_DART
Worst Weather USA
just completely forget about the driveshaft measurement!
you see why im asking? some swear by the shaft----some dont use the shaft in the equation !
[Re: CrAzYMoPaRGuY]
#973501
04/16/11 04:04 AM
04/16/11 04:04 AM
493_DART
Worst Weather USA
I have the Rossler. Please post the other 99 charts. Or how about this --- 5 other charts?
this is the meaning of my thread
[Re: moparniac]
#973503
04/16/11 09:23 AM
04/16/11 09:23 AM
deaks
robin hood country
I went off the rossler chart and mine is 6 degrees down on SS springs but i think you might need a little less with caltracs. Mick
[Re: 493_DART]
#973504
04/16/11 10:02 AM
04/16/11 10:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you dont set the working angle first you could have WAY to much angle and still be right if you go off the trans... for instance IF your trans is 12" above the pinion the angle could be correct but the joints would be in bind
