Re: A833 parts swapping
[Re: @#$%&*!]
#973148
04/14/11 03:51 PM
04/14/11 03:51 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Tailshaft housing off the A O/D 30 spline output shaft trans will work. Mainshaft is different. Bearing retainer may swap, depends on front bearing size. I have some info available here: http://www.brewersperformance.com/orderinfo.htmOr you can always send me an email with questions. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: @#$%&*!]
#973150
04/15/11 08:55 AM
04/15/11 08:55 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for the reply, Dan. I guess I should have stated the '67 833 is from a 383 and has a 4.8" retainer. Did you mean that the tailshaft AND housing will swap? It's an iron A-body OD with the big yoke.
Tailshaft housing off the A O/D 30 spline output shaft trans will work. Mainshaft is different. Bearing retainer may swap, depends on front bearing size... Dan
A 67 383 would not have a 4.8 retainer , that size retainer didn't start till the 68 model year.
What Dan said is if the trans has a 30 spline tailshaft housing (many alum tailshaft od a/f body 833 are sized to the 27 spline 904 size) it will swap but the MAINSHAFT, the piece the gears ride, on will not , the spot for 3rd gear(in an Od it's 4th) is a different diameter ... smaller.
