Re: AMD panel disappointment
[Re: DAYCLONA]
#972190
04/17/11 02:42 PM
04/17/11 02:42 PM
Posts: 1,179 Canada
demon
Canada
I've installed a lot of AMD sheetmetal. No real complaints except for some relatively minor stuff. Yes, the side marker recesses on some have been a bit too large, and most panels have some surface flaws. Overall fitment hasn't been an issue for me. Most recently I did AMD rockers, door skins, 1/4 skins, outer wheel houses, trunk extensions on a Challenger. The rocker fit was terrific. Very happy. The door skins had some lumps and waves but fit very well and after some high build primer they blocked straight. 1/4 skins were a great fit and straight. No filler at all except the top joint. Wheel houses also fit fine and matched the 1/4 well. The original line up holes along the inner flange did NOT match but no big deal. The trunk extensions fit fine too but the holes for the rear valance did NOT match the 1/4. I would suggest they don't bother putting the holes in if they aren't in the right location. But that's pretty minor really and like I said- No body filler was needed AT ALL. Overall I would rate the AMD Challenger stuff i used very highly
[Re: demon]
#972191
04/17/11 07:16 PM
04/17/11 07:16 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
I think whats important to note in this thread is that even though some "flawed" parts do end up in peoples hands from AMD the fact that they allways strive to make it right should not be overlooked.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
[Re: 69charger440_6pa]
#972192
04/18/11 09:41 AM
04/18/11 09:41 AM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Driver wheel housing to quarter alignment, with the rear lip clamped in place is out 1 inch over a 14 linear curve. ![](http://i546.photobucket.com/albums/hh425/chrisd6875/GEDC0681.jpg) The flange was also off by the same amount where it meets with the original inner housing. I had to relief cuts in the flange to bring it in to match the inner, and then cut the whole lip off to make it meet the quarter panel. Before I cut it, I called AMD and spoke with a guy in the"install department" who just did a 70 Cuda and did the same thing. Quarter panel and drop-off are good. ![](http://i546.photobucket.com/albums/hh425/chrisd6875/Photo_031711_005.jpg) ![](http://i546.photobucket.com/albums/hh425/chrisd6875/Photo_031811_003.jpg) I'll be doing the other side in a few days, I probably will not use the AMD Housing.I already checked, and it does not fit the quarter either.
#972193
04/18/11 10:07 AM
04/18/11 10:07 AM
Posts: 1,057 Ont, Canada
gygeneral
Ont, Canada
This is true. I bought both quarters for my 71RR over a year ago. Just getting around in installing them. The left required some surgery , but the right was real bad. AMD, even after a year sent me a replacement panel without hesitation, I have not installed it yet so I can't comment if its any better. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: gygeneral]
#972194
04/18/11 11:16 AM
04/18/11 11:16 AM
cudabitten
eastern, pa.
I agree, when I emailed AMD, I received a reply the next morning. It included two phone numbers, one which put me in direct contact with the shop. When I called, the two guys I spoke with were very honest. They could have easily put me off, and not admitted about thier product. So by them explaining to me that I was on the right track, it reduced my frustration, and made me feel like they were part of the solution. Back in the day, I would pop rivet some aluminum or use fiberglass and bondo it up. While all of the parts are not perfect, I think they are still evolving, and will get better in the future.
[Re: domingo]
#972197
04/21/11 09:41 PM
04/21/11 09:41 PM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
Well, there is no need for us to exchange this panel, only using the front part anyways. Let me say this though, if we would have needed it, would have sent it back for sure. Now that we cut the panel and fit it to the car, the metal on the wheel opening lip is nowhere near the orig panel width. Luckily, we are trimming the lip by 1/2 inch to max space for the tire. As far as this panel goes, thats two strikes!
[Re: AeroMonte]
#972200
05/04/11 07:53 PM
05/04/11 07:53 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
I'm using AMD sheetmetal on a 70 Charger. The one piece trunk floor was fantastic. Fit the rails very nice. I'm doing the outer wheel houses now and they look like they stick out to far at the rocker about an inch. I can modify them but I'll wait to see how the quarters fit first. The roof skin fits great as does the roof brace and rear frame brace. It's all better than having nothing to work with at all.
yes it is better then nothing..
i found out the hard way that the dodge outerwheel houses had to be retooled at one time so the earlier versions fit like total garbage ![](/ubbthreads/images/graemlins/flame.gif) i see you are now having the same issue ![](/ubbthreads/images/graemlins/blush.gif)
