Re: AMD panel disappointment
[Re: Bull1tt]
#972172
04/12/11 08:04 PM
04/12/11 08:04 PM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
Last pic. I'm not to thrilled about the quality...... stamped on the body line.
[Re: cudabitten]
#972176
04/15/11 12:13 AM
04/15/11 12:13 AM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
Ive been workin out problems with the outer wheel housings to quarter panel meeting areas on my 74 barracuda. The wheel housing is way off.It also did not match the original inner housing. I had to cut slices in the flange area and cut the complete lip off. A lot of extra metal work that I did not count on. Called them up and they were honest and admitted that they knew about this. But still???I'll be doing the other side in a few weeks, and not looking forward to it.
I had the same problem with the inner wheel housing not meeting up with the quarter panel. I don't understand how this issue is the same on the e bodies and b bodies. Mine were 1/4" too short so we had to add 1/4" to the wheel tub.
[Re: Q5_Ed]
#972178
04/16/11 09:56 AM
04/16/11 09:56 AM
gygeneral
Ont, Canada
Are you saying there is a problem with the wheel houses on the 69 B-body??? I am needing to replace both inner and outer.
Ed B
NO, I am making reference to the 71B quartrs I just installed. I have no experience with the 69B's.
[Re: gygeneral]
#972179
04/16/11 11:50 AM
04/16/11 11:50 AM
Posts: 1,896 New England
Q5_Ed
New England
OK Thanks, if anyone has had experience with other fit issues or success please chime in.
Ed
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
[Re: Q5_Ed]
#972180
04/16/11 01:19 PM
04/16/11 01:19 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
Ed
Troy Angelly just replaced my quarters and partial outer wheel wells on my '69 RR with AMD's products. They needed a lot of tweeking, especially at the lower window corners and at the tail light extensions. I think he had to do some massaging of the lower body lines too. Regarding the wheel wells; I believe he cut out the bad area in the originals, where they spot weld to the quarters, and then used the new wells for the replacement metal instead of replacing the entire well. Although AMD seems to have the best product out there they are not like NOS or donor car panels. Remember, they don't have the original dies and presses so they are not going to be a perfect fit, they will require some work so be prepared for some additional time and effort.
[Re: Mopar Grandpa]
#972181
04/16/11 02:37 PM
04/16/11 02:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Ed
Odd?.......I had actually quite the opposite "experience" with the AMD 69 qtrs that I installed personally on this customers car, the original dutchman panel and gutter rails stayed in place, only 1 door jamb was replaced, the qtrs pretty much fell into place, the original taillight potmetal caps bolted on and aligned perfectly, all the panels lines, lined up with the factory doors, and other countours of the car, no filler was needed anywhere on the skin, other than the obvious blend area in the roof pillar and rocker seam, I fitted every other panel and trim, glass, etc before final welding, so that no surprises would pop up during final assembly (what o0ne should do regardless of panel's origin).....my only issue was with the marker lites, the stamping was a tad bit larger, but easily rectified, I used Goodmark trunk/qtr extentions that were supplied by the customer, and suprisingly they worked rather well with the AMD qtrs......I installed a good number of AMD qtrs, fenders,hoods,trunks, dutchman panels, tailpanel,etc,etc,etc, on E and B bodies, and have yet to encounter any panel that requires the kind of "tweaking" that some have encountered,....I buy my panels just like the rest of you, either direct from AMD, or thru a local supplier,.....in fact the panels I installed on this customers RR were the "left over" last set at Autobodyspecialties in Conn, I was late to pick thru the several sets they recieved, I got what was left, there were several dimples from handling, but nothing a few minutes with a pick and dolly couldn't straighten out...
Mike
[Re: DAYCLONA]
#972182
04/16/11 02:39 PM
04/16/11 02:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#972183
04/16/11 02:41 PM
04/16/11 02:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#972184
04/16/11 02:45 PM
04/16/11 02:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#972185
04/16/11 02:55 PM
04/16/11 02:55 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: jmaxwdg]
#972189
04/16/11 10:44 PM
04/16/11 10:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Dayclona I'm jelous. We are on our 4th set of road runner quarter panels and the stampings should come with there own troll to help straghten them . They must like you better.
Don't bet me wrong these are the best PATCH panels to date and couldn't do it without them.
Anyone want a cheap pair of AMD Challenger door skins. I wouldn't even bother using them. Sell at half price.
Like I've said in past posts on AMD sheetmetal, it can be a crap shoot, if you grab the first few pcs 'hot off the press" so to speak when the pcs are first offered, chances are you get the sharper/crisper panels that are made at a slower pace, but as production ramps up, quality goes down, as well as wear on the dies, or damage to the dies,.....but it's also a double edged sword, sometimes the first initial run can be frought with problems, resulting in poor/badly stamped pcs, and then after "fine tuning" production, later run pcs improve,...but being made in SE Asia, quality control is only as good as the US counterpart/controller wants it,....plus another factor is that most of the Asian workforce has no understanding of the importance that we (the end user) place on the correctness of these panels, or even their intended usage,......I work as a Millwright, erecting steel/precious metal mills/foundries and it's equipment,...I've done my "tour" of working in SE Asia/ India, and know what goes on firsthand at these plants......it's not good.....
But I do applaud AMD's efforts for bringing to market, panels/pcs most thought we would never see
Mike
