Gear Vendor install-E Body
#972087
04/12/11 04:48 PM
04/12/11 04:48 PM
Posts: 860 lancaster,california
johnnycuda
Hey,just wondering if anyone out there has performed a install on a Gear Vendor in a E body,,if so,how much modification was needed to clear the tunnel?,Presently my 'Cuda has a 499/727 combo with a 8 3/4 rear. Thanks in advance for any info offered or supplied.If you happened to have taken pics,please post them here or email them if possible,,thanks again!!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Gear Vendor install-E Body
[Re: johnnycuda]
#972088
04/12/11 06:34 PM
04/12/11 06:34 PM
Posts: 396 BC
70RT27N
BC
[Re: johnnycuda]
#972090
04/13/11 12:08 AM
04/13/11 12:08 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Ask them yourself in person at Spring Fling this weekend. They will have a booth at the show.
[Re: Mopar73340]
#972093
04/13/11 04:13 PM
04/13/11 04:13 PM
johnnycuda
Hey guys,thanks for the info,I've installed this before in my Dodge truck,pretty simple install,,it's the amount of massaging required in my '70 was my concern.I talked to G/V a while back,was told I had to cut out a piece of the floor,and make a patch to clear tunnel,,I planned on having a spare driveshaft shortened in case a problem arises at some point. Hey,Maverick,my email went done yesterday,supposed to up again in a day or so,,sorry.
[Re: 70RT27N]
#972094
04/13/11 04:18 PM
04/13/11 04:18 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
This isn't an E body, but well worth the read...
https://board.moparts.org/ubbthreads/show...part=1&vc=1
I've put some good miles on the GV since I made this thread and it's performed flawlessly. Can't image that an e-body would need that much massaging. Remember, you can also lower the unit away from the floorpan with a slight modification to the tranny crossmember...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
