Re: 727 Trans Kick Down Linkage Question-71 RoadRunner 383
[Re: John_Kunkel]
#971975
04/14/11 05:09 PM
04/14/11 05:09 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Something doesn't look right, I don't think that should be angled down like that.
Possibly because the "C" shaped link is standing near verticle, in some installations it leans forward at an angle which would bring the top link closer to horizontal. That would also close up the gap in the slot.
Looking at it again after John mentioned this I can see your problem and I believe it is caused because you have run out of adjustment on the rod going down to the trans which is not allowing the carb attachment to go fully forward.
Did you piece this setup together, you may have the wrong lever down at the trans wich is why it is at the end of travel , or you put it on upside down ?
[Re: JohnRR]
#971980
04/15/11 12:21 PM
04/15/11 12:21 PM
JohnRR
Did you miss this ? unbolt the down rod and see if everything levels out and it pulls forward, if it does you either have the wrong throttle cable bracket or the lower rod is too short/bent wrong or the lever on the trans is the wrong oreintation.
I asked , is this parts from one source or did you piece it together ?
[Re: 69Stinger]
#971982
04/15/11 06:14 PM
04/15/11 06:14 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
OK - here's some more pics - the lever is definitely at an odd angle when looking at it straight on.
That bracket is a 440 one and you should replace it with the right one.
Here is one available at a reasonable cost. http://cgi.ebay.com/ebaymotors/MOPAR-383...=item5ae001dbbe The seller is Jimmy Borros and he knows his 71 up b-body's well, and has helped me out allot over the last couple years.
[Re: 69Stinger]
#971987
04/16/11 12:04 PM
04/16/11 12:04 PM
JohnRR
Air grabber cars like mine came off the line with Holleys.
What Holley do you have , the original or an aftermarket with the Chrysler adapter ?
Why would you remove a holley and put on that junk performer 750 , Everything I read on the internet says Holleys are the best carburetors ever built ?
[Re: 69Stinger]
#2156904
09/18/16 05:53 PM
09/18/16 05:53 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Sorry for digging up an old thread
Was responding to kickdown adjustment on another thread when I dug this up
Does anyone make the correct 1971 one piece kickdown linkage pictured in this thread
I see only brand new reproduction three piece kickdowns used on the older big block cars
And then of course the excellent pictures provided here with the difference between the 383 and 440 bracket that attaches to the manifold for the throttle cable and adjustment bolt for rod
Looking for individual pieces as some of my swivel holes are elongated or wore out where the adjustment is on the bracket itself. A lot of free play
1971 383 Magnum one piece rod kickdown linkage / bracket
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2157743
09/19/16 09:46 PM
09/19/16 09:46 PM
Posts: 16,167 Mesa, Arizona
dart4forte
Mesa, Arizona
I have a Carter 9536 sitting at home. It's the performance replacement for the 340/383 AVS.
“So if it’s on the internet it must be trueâ€
Abe Lincoln
