Re: 1971 GTX Fender tag Question V7W and V8W Help!
[Re: lawnmanlex]
#971496
04/11/11 10:52 PM
04/11/11 10:52 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
The V7W is the pin stripe. White in this case. All 71 GTXs came with the pin stripe, although most seem to be omitted during restoration.
The V8W and N96 are mutually exclusive on a 71 GTX. It's one or the other. That just doesn't add up.
Post the tag pic.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: Alaskan_TA]
#971499
04/12/11 01:20 AM
04/12/11 01:20 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
V8W is a legitimate code as well as V8X and V8Y. Here's a great site 71 Satellite stripes. Barry. I think you are asking about M75. That's the code for the bumper/valence stripes. On a GTX, V8* is the fender/tank track stripe. Quote:
The two codes are V7W and V8W but the whole problem is that it is a N96 Air Grabber car.
Are you thinking V8* striping was not available with N96? Is that what you are getting at?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 6bblgt]
#971504
04/13/11 12:40 AM
04/13/11 12:40 AM
471Magnum
Space Station #5
Might just be a code quirk. Bottom line though is that you can't have the stripe AND the Air Grabber. Well I guess you COULD, but it would sure look dorky.
-Jim
[Re: 471Magnum]
#971505
04/13/11 12:47 AM
04/13/11 12:47 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I wonder if thats the code for the blacked out area behind the fiberglas a/g buble on the vent part of the hood? sort of like the roadrunner decor package? just a guess..
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: lawnmanlex]
#971508
04/21/11 12:41 PM
04/21/11 12:41 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
The V8W is some kind of misprint on the tag. N85 N96 R26 V7W V8W C TD + M21 M25 M31 N41 N42 + C55 C62 G36 J45 J52 L31 VIW -U- AO1 A36 B11 C16 FE5 P6XW TX9 926 046212 E86 D32 RS23 U1 G 121984 --- 26 END --- YX? RS23 U1G 121984
