Re: 74 Road Runner Wipers
[Re: indytex96]
#971275
04/11/11 11:42 PM
04/11/11 11:42 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
Are you sure you have a 2 speed motor and a 2 speed switch? And did you make sure you have the bracket to the motor on the right side of motor?
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: indytex96]
#971276
04/12/11 12:16 AM
04/12/11 12:16 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
they don't park... did you mean, they don't hide down the hood simply stoping lower still on glass, or simply won't turn off ? or stops on wherever place you shut off the switch ?
[Re: indytex96]
#971278
04/12/11 01:43 PM
04/12/11 01:43 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Can't say for sure, as I don't know exactly how they work. But if the motor is new, I suspect the switch is bad. IIRC, if the switch doesn't have a good ground, this MAY cause the symptom you are experiencing. The switch you are using IS installed in the dash now, isn't it? And the dash does have a good ground to the car? That's as far as my thinking takes me. Not home now, so I can't reference the FSM. Sorry.
[Re: MoparMarq]
#971279
04/12/11 04:32 PM
04/12/11 04:32 PM
NachoRT74
Valencia, España
blue wire it motor is KEEPS HOT when you turning off the switch. That makes to reverse the motor to get the cancellation cam cutting the power to armature inside the motor, BUT WIRE STILL REMAINS HOT.
Check if that wire is being powered when turning off.
I'll try to find a guide to test of this system anyway, I know there is someone around
