carb ?update
#970817
04/10/11 09:01 PM
04/10/11 09:01 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
this is drivin me nuts.ive replaced every part of this carb and tuned till my fingers bleed,got it ideling perfect,great response and runs smooth down the road but then after a while when i accelerate it blows gas out the front vent.fuel pressure is steady at 6lbs.if i let it sit for a while it runs fine again for a while.
Re: carb ?
[Re: Quicktree]
#970822
04/10/11 09:17 PM
04/10/11 09:17 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
try another fuel gage. what kind of regulator?
put a brand new guage on it.its a holley reg.
Re: carb ?
[Re: Eric]
#970825
04/10/11 10:25 PM
04/10/11 10:25 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
ive seen it many times where the vent baffle droops a little and contacts the float when you try and set it to the correct level.
try setting the float about 1/2-3/4 of a turn lower than the "correct" height to see if it eliminates the flooding condition you're having. if this fixes the problem, you need to tweek the vent baffle upwards a bit. i find that shortening the baffle can help in this situation as well.
ive also found that the nitrophyl or brass floats are less likely to experience this issue than the plastic floats(which have much more flexible arms).
if that doesnt do it, then it really either has to be a needle and seat, or needle and seat o-ring, or the regulator is malfuctioning. if the regulator is old, the diaphragm may be dried out and stiff.
Re: carb ?
[Re: bonefish]
#970826
04/10/11 10:42 PM
04/10/11 10:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you using a liquid filled gauge... drain it if you are... also are you watching the gauge as the problem occurs
Re: carb ?
[Re: bonefish]
#970829
04/11/11 10:09 AM
04/11/11 10:09 AM
Quicktree
no liq.gage,it has new needle and seat.the pressure stays steady.its gotta bee somthing with the float hangin up.
did you say this was on the front or back? do you have jet extensions?
Re: carb ?
[Re: Quicktree]
#970830
04/11/11 12:07 PM
04/11/11 12:07 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
its on the front,it does it sittin still or movin.
