carb ?update #970817
04/10/11 09:01 PM
04/10/11 09:01 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this is drivin me nuts.ive replaced every part of this carb and tuned till my fingers bleed,got it ideling perfect,great response and runs smooth down the road but then after a while when i accelerate it blows gas out the front vent.fuel pressure is steady at 6lbs.if i let it sit for a while it runs fine again for a while.
Re: carb ? [Re: bonefish] #970818
04/10/11 09:04 PM
04/10/11 09:04 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Sounds like maybe the floats to high but I need more informaiton. What kind of carb?
Re: carb ? [Re: DodgeCharger] #970819
04/10/11 09:08 PM
04/10/11 09:08 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
oh yeah,its a 850 dp i check the float level after this happens and its perfect.
Re: carb ? [Re: bonefish] #970820
04/10/11 09:14 PM
04/10/11 09:14 PM
Mohnton, Pa
Mohnton, Pa
I would try taking the front float down a little. I will admit for years I ran mine higher than what they are suggesting. If you have sight glass the level should be below half.
Re: carb ? [Re: DodgeCharger] #970821
04/10/11 09:16 PM
04/10/11 09:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
try another fuel gage. what kind of regulator?
Re: carb ? [Re: Quicktree] #970822
04/10/11 09:17 PM
04/10/11 09:17 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
put a brand new guage on it.its a holley reg.
Re: carb ? [Re: bonefish] #970823
04/10/11 09:20 PM
04/10/11 09:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check to see if the float may have a hole in it. has to be pressure,float issue. not a lot more it can be.
Re: carb ? [Re: Quicktree] #970824
04/10/11 10:12 PM
04/10/11 10:12 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Needle and seat...been there...got the T-shirt.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: carb ? [Re: Eric] #970825
04/10/11 10:25 PM
04/10/11 10:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
ive seen it many times where the vent baffle droops a little and contacts the float when you try and set it to the correct level.
try setting the float about 1/2-3/4 of a turn lower than the "correct" height to see if it eliminates the flooding condition you're having.
if this fixes the problem, you need to tweek the vent baffle upwards a bit.
i find that shortening the baffle can help in this situation as well.
ive also found that the nitrophyl or brass floats are less likely to experience this issue than the plastic floats(which have much more flexible arms).
if that doesnt do it, then it really either has to be a needle and seat, or needle and seat o-ring, or the regulator is malfuctioning.
if the regulator is old, the diaphragm may be dried out and stiff.
Re: carb ? [Re: bonefish] #970826
04/10/11 10:42 PM
04/10/11 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a liquid filled gauge... drain it if
you are... also are you watching the gauge as the
problem occurs
Re: carb ? [Re: MR_P_BODY] #970827
04/10/11 11:11 PM
04/10/11 11:11 PM
Fredonia,NY
W
wafflebatter Offline
W
Fredonia,NY
definitely change the needle and seat, I've been there with Eric, seen it, done it
Re: carb ? [Re: wafflebatter] #970828
04/11/11 09:52 AM
04/11/11 09:52 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
no liq.gage,it has new needle and seat.the pressure stays steady.its gotta bee somthing with the float hangin up.
Re: carb ? [Re: bonefish] #970829
04/11/11 10:09 AM
04/11/11 10:09 AM
Q
Quicktree Offline
Quicktree  Offline
Q
did you say this was on the front or back? do you have jet extensions?
Re: carb ? [Re: Quicktree] #970830
04/11/11 12:07 PM
04/11/11 12:07 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its on the front,it does it sittin still or movin.
Re: carb ? [Re: bonefish] #970831
04/11/11 01:17 PM
04/11/11 01:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would look at a bent float.
Re: carb ? [Re: bonefish] #970832
04/11/11 01:26 PM
04/11/11 01:26 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
there can be dirt in the line.flush the line.
Re: carb ? [Re: bonefish] #970833
04/11/11 07:12 PM
04/11/11 07:12 PM
Champaign IL
LXguy Offline
LXguy  Offline
Champaign IL
Don't know if this helps, but "tyranny" has two "n"s.
1971 Dodge Dart Swinger 5.9 Magnum, built 904 ET 11.70 / 113 mph Want to swap a Magnum into your Mopar? www.magnumswap.com
Re: carb ? [Re: LXguy] #970834
04/14/11 08:13 PM
04/14/11 08:13 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
welli took it apart again for the umteenth time and still remained baffled,ive never been baffled like this before,this has got to be one of the most baffling things ive ever seen.then finally some one mentioned baffle and thats the only thing on this carb that i didnt look, at or replace and sure enough it was pointing down just enough so that after everything got good and hot it would hold the float open.i turned it upside down and put every thing backi together and i am no longer baffled.thanks all for your help it could of been any or all that was sugested.But Dwayne gets the cigar.
