Thicker oil for the hemi ? #969587
04/08/11 09:23 PM
04/08/11 09:23 PM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
we've got two 2005 5.7's, one in a durango, the other in a ram. Both vehicles approx. 100,000 mi. Is there ever a time to change to thicker oil or should I continue to use the 5-20 as specified ? Thanks
Re: Thicker oil for the hemi ? [Re: DOUGG] #969588
04/08/11 10:21 PM
04/08/11 10:21 PM
IN
ahy Offline
ahy  Offline
IN
I ran 5W-30 Mobile 1 in an '06 Durango I just traded in today. 165K and runs and drives great. Oil consumption same as new - 1 quart during the oil change interval. I just wanted the extra protection if/when it was run hard and hot. It didn't seem to bother the MDS either. 20W just seemed too light to me.
It it was mine, I'd go ahead and switch to the 5W30.
Re: Thicker oil for the hemi ? [Re: DOUGG] #969589
04/08/11 10:23 PM
04/08/11 10:23 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
No reason to change. Keep on rolling. These motors were designed to last 200,000 or more. Keep up with regular maintenance and oil changes and you will be fine.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
