Main Bearings #969435
04/08/11 06:39 PM
04/08/11 06:39 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Mild Performance Build 413, Do I use Full, 3/4 or 1/2 groove main bearings?
Re: Main Bearings [Re: Hotlumpy] #969436
04/08/11 06:55 PM
04/08/11 06:55 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Full will be fine .
Re: Main Bearings [Re: JohnRR] #969437
04/08/11 09:17 PM
04/08/11 09:17 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Full will be fine .
Some recommend using a high volume oil pump with full groove bearings, is that truly necessary or can you use the stock sized oil pump to save on horsepower?
Were talking performance street build not to exceed 6000rpms.
Re: Main Bearings [Re: CompSyn] #969438
04/08/11 09:29 PM
04/08/11 09:29 PM
IN
ahy Offline
ahy  Offline
IN
The full groove with typical performance clearances - around .0025" - will likley have low hot oil pressure at idle with a standard pump. A high volume pump helps a lot. I'm running the full groove/HV pump and have a bit over 20 PSI at hot idle. I'm happy with that but wouldn't want to go much lower.
There was a long thread on main bearing groove type a few weeks ago. Long story short, many have done well with the 3/4 groove bearings and recommend them. Even so, if/when I build again I'll probably stay with full groove/HV pump to give the rod bearings all the lube I can.
Re: Main Bearings [Re: ahy] #969439
04/08/11 10:03 PM
04/08/11 10:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I run half groove bearings with a standard pump have 40 psi at hot idle and spin it to 7500 every shift and I checked my bearings at 150 passes and they look like new.
If you pay attention to the details and do a quality build no need for 3/4 or full grove bearings IMO all you do is lose bearing surface.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Main Bearings [Re: dusturbd340W5] #969440
04/08/11 10:45 PM
04/08/11 10:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: Main Bearings [Re: MoparforLife] #969441
04/08/11 11:29 PM
04/08/11 11:29 PM
w a mild perf build . I would open up the angled gallery to crank oil holes & restrict the 1-2-3-5 vertical cam bearing passages to 1/16" and if you feed the heads externally then reinstall the #4 cam bearing turned a bit to block em or instead of externally feeding the heads you can turn the bearing and tap into the main horizontle gallery and T ing over to halfway up the angled oil pasage to each head on each side which'd b hidden & only after doing either of these bypasses then you can restrict that vertical crank to cam passage to 1/16" like the 4 others. Cam bearings leak ALOT of oil. Overkill but rods fed from the #4 main have starvation issues and you may decide to get on your "mild performance build"
