power locks quit workin??? #969020
04/07/11 09:59 PM
04/07/11 09:59 PM
Brandon, Manitoba, Canada
Roadripper Offline OP
My power locks on my 05 caravan quit working, so i went to check the fuse panel to see if any are blown . Turns out i can't figure out which fuse it is??? there is nothing in the owners manual that points to power locks Any ideas as which fuse it would be or could it be something else thanks Mike
Re: power locks quit workin??? [Re: Roadripper] #969021
04/07/11 10:02 PM
04/07/11 10:02 PM
Under My Car
Mopar_Country Offline
Under My Car
You might hook up your test light and check each fuse for power on both sides of the fuses. You may find one that only lights on one side.
Re: power locks quit workin??? [Re: Roadripper] #969022
04/07/11 10:09 PM
04/07/11 10:09 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
You probably need the bcm updated. Try unhooking battery and see if they work after it is hooked back up. Updating bcm has fixed lots of these.
Re: power locks quit workin??? [Re: Roadripper] #969023
04/07/11 10:39 PM
04/07/11 10:39 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
did you look inside of the cover, for the fuse panel? the schematic should be cast into the plastic? there should be one under the dash, and one under the hood. should contain a decal or cast in diagrams.
it's been suggested by a buddy, if you disconnect the battery for a couple of minutes and pull the BCM fuse out, then reinstall them, the locks should work again.
