I just put a 727 pump together last night, 71-72 vintage, the chamfers look like the ones above but they were slightly different. Your first picture is darker than the second, but the gear and the rotor had a mark on them, the side of the gear with the mark had a smoother chamfer than the other side so I put that marked side s together and toward the converter. Trans had been rebuilt before and I didn't pay attention to which side was which when I first disassembled it to clean it, I will from now on though.
