Re: Thermoquad guru's help.....
[Re: 70rrclone]
#968432
04/07/11 02:16 PM
04/07/11 02:16 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
You may be describing any smog 440 but keep in mind the thermoquad uses small primaries and LARGE secondaries. Try to verify that the secondaries are indeed opening. If the choke is not all the way off or if there is interference with the aircleaner base they will not open. If that checks out, make sure the choke pull-off is allowing the air door to open. (the air door is directly above the secondary throttle plates). ![](/ubbthreads/images/graemlins/drive.gif)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: RapidRobert]
#968435
04/07/11 03:57 PM
04/07/11 03:57 PM
Posts: 1,323 La Grange, Ky
70rrclone
La Grange, Ky
8 deg initial timing, it had a 3310 holley on it that was flooding it with gas. it runs alot better with the TQ. it has the stock cam. also if you slowly give it gas it has a slight hesitation/bog.
shane
[Re: 62maxwgn]
#968437
04/07/11 04:08 PM
04/07/11 04:08 PM
70rrclone
La Grange, Ky
also this carb was set-up/used on this engine while it was in a motorhome in Denver Co. would altitude compensation be an issue? carb info.
Model Application 9150 78 440 Truck HD AT CA (4095441)
Pri. Sec. Rod 4099 5125 2110
bore 1 1/2
shane
