Gen 3 Hemi's are the new cool. What members are making.
#968115
04/06/11 10:28 PM
04/06/11 10:28 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
What members are making hi-po or cool parts for them? Maybe we can get everyone in on one thread to list what they do or where they got their stuff. We make wire sets using our special boots that fit into the Gen 2 and Gen 3 "Indy" style valve covers. We also invented a way when re-locating the coil packs, to keep the contact spring in the boot, and the same boot grips the coil pack, so no zip ties are needed. Mike Ware was the first to dyno our Hi Energy FireCore 6.1 Coil Packs on Steff's new build. They absolutely made a horsepower and Torque difference. SheraDon Performance will be dynoing them next week on a supercharged extreme engine. How strong are the factory manual transmissions? Can the factory rearends become "BulletProof?" What other members are developing parts for the 5.7/6.1/6.4 Hemi's? From this ![](http://img.photobucket.com/albums/v605/sunroofgtx/Custom%20Wire%20Set/CustomWireSet010.jpg) To this. ![](http://img.photobucket.com/albums/v605/sunroofgtx/Custom%20Wire%20Set/CustomWireSet006-1.jpg) ![](http://img.photobucket.com/albums/v605/sunroofgtx/Trophy%20Room/FireCore%20Engines/09_Challenger_35.jpg) ![](http://img.photobucket.com/albums/v605/sunroofgtx/Trophy%20Room/FireCore%20Engines/DSC_1313.jpg)
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Gen 3 Hemi's are the new cool. What members are making.
[Re: sunroofgtx]
#968116
04/06/11 10:38 PM
04/06/11 10:38 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Rick, my motor is a 04, that had the crossover wires. can i convert to those coils you make and run those wires with the hemi msd box? that indy motor is downright sexy
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#968117
04/06/11 10:54 PM
04/06/11 10:54 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
hey!!! i recognize that bottom pic. i think we where the first to run the relocated coil pack using a valve cover other that stock. worked out well.
i still have some stuff up my sleeve. pretty much slowed myself down and only doing camshafts now.
factory rear ends seem to blow easy these days. i did a cam for a car that ended up making 897 at the wheel. nothing too crazy. first shakedown pass she ran a 6.22...at the nmca race it ran a 9.84 off a 6.80 spinning. the car ate the 225 mm rear that is made by getrag. ended up with a 8.8 ford in it. steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#968118
04/06/11 11:48 PM
04/06/11 11:48 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I love my SRT Challenger. But I don't make parts so this is just a bump I like to see what's out there for these cars but I want gofast parts not pretty stuff ![](/ubbthreads/images/graemlins/smile.gif) but if it's fast and looks good doing it.it's going to go over big. My almost stock SRT went 8.36 at 86mph last time I had it out. And it's a 4100# pig ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: FastmOp]
#968119
04/07/11 01:17 AM
04/07/11 01:17 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Well we make a really nice waterjet cut 3/8" Hemi motorplate. We can include an alternator mount, electric water pump, stainless bolt kit, or even cut logo's or names into the plate.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: FastmOp]
#968120
04/07/11 01:30 AM
04/07/11 01:30 AM
nhramark
Wheels up, MO
We also make 3/8" stainless or mild steel exhaust flanges.
And we are about 3/4 done designing a sheetmetal intake manifold that will fit under the stock hood. It would be a weld up kit that the customer would assemble. Just wondering if there would be any interest in that before we put anymore work into it.
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#968121
04/07/11 10:49 AM
04/07/11 10:49 AM
Posts: 12,424 Taxes & Virus's R-US, NY
Dragula
I want a plate that mounts a reverse rotation Procharger that's belt driven, uses an electric water pump and a mancini mini alternator....But the N/A plate looks really good too.
[Re: Dragula]
#968122
04/07/11 11:45 AM
04/07/11 11:45 AM
Posts: 833 MN
hemidup
MN
Came up with a valley tray tray cover using DEI heat reflective material on the bottom side. Also QPQ Melonite treated rockershafts, rockershaft ties, clamps and end plugs.
Jerry Williams.
[Re: gremlinsteve]
#968124
04/07/11 12:38 PM
04/07/11 12:38 PM
sixpackgut
Charleston
nhramark, i sent you a pm, did you get it?
[Re: nhramark]
#968126
04/07/11 07:52 PM
04/07/11 07:52 PM
Posts: 2,129 Vermont
TrWaters
Vermont
The originator of...... Billet valley covers. Hard Chrome rocker shafts with removable O-ring end plugs Billet rocker shaft hold downs Billet rocker shaft clamps. Billet 5.7 intake spacers ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: sunroofgtx]
#968133
04/07/11 11:15 PM
04/07/11 11:15 PM
gremlinsteve
houston texas
the one today made 700 ft lbs of torque at 2000 rpm...on 426 inches btw
steve-o
[Re: gremlinsteve]
#968134
04/07/11 11:22 PM
04/07/11 11:22 PM
sunroofgtx
Cleveland
Steve, that is so impressive. amazing. You guys working on these things are the new generation of Hemi guru's. Very nice..
Steve , how have you been??
