Motorhome 440,,carb@intake,,what choice's #967938
04/06/11 06:49 PM
04/06/11 06:49 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
I have the origional intake and thermo quad on my 76 Winnie and just not satisfied with the way it work's or performs,intake is a smogger unit and the TQ has surging issues, seem's like the motor starts out pulling good when you first hit the gas and then flattens out after about 30 ft of travel and seem's lazy after that and get a whopping 4.5 mpg,,this thing need's help and would like some suggestions on a carb and intake selection.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967939
04/06/11 06:59 PM
04/06/11 06:59 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
4.5 mpg ? ... I got 6.6 with a pig-fat Berri-crab that was so rich(when I picked it up) ... my wife could not follow behind me.
What # is the carb ? .... R U sure the exhaust flapper is free ? (Best even to TIE IT open)
And there ARE much better choices as far as intakes.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967940
04/06/11 08:20 PM
04/06/11 08:20 PM
scratchnfotraction Offline
I have a 78 mh 440 that had a stock smogger intake and thermobog
swaped it for a weiand action plus with a 650cfm carter performance carb
of course shaveing 60 foot of MH,adding the intake carb,striping down a short bed truck adding 3.91sg,manual VB,mono spring with lift bars
it got plenty of torque with a stock 440,i am sure i will get a little better mpgs than that
or try a Q-jet,holley spredbore 650 double pumper thermobog replacement those both worked good on mine when first getting it running
Re: Motorhome 440,,carb@intake,,what choice's [Re: scratchnfotraction] #967941
04/06/11 08:29 PM
04/06/11 08:29 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
scratchN ..... suggesting a Q-J ? ... go sit in the corner - NO SOUP ferr U !
thermobog ? ...will you ever learn NOT TO remove the secondary AV flapper ? ....or maybe get the proper tool to adjust it ..?? ...
That's right ...I said it ...
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967942
04/06/11 08:29 PM
04/06/11 08:29 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
You have a fuel delivery problem.
It's delivering the wrong kind of fuel.
- Stu Harmon
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967943
04/06/11 09:21 PM
04/06/11 09:21 PM
the TQ has surging issues, and would like some suggestions on a carb and intake selection.
Carb issue, I'd have Demonsizzler sell you a super quality pro prepped TQ & keep your intake to minimize your downtime then w it running good you'll b in a more neutral frame of mind to decide if you want to sink $$ into other areas of it.
Re: Motorhome 440,,carb@intake,,what choice's [Re: feets] #967944
04/06/11 09:26 PM
04/06/11 09:26 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Yeah ain't that the truth,, but it is what it is and I have to deal with it, this Thermo was sent out and rebuilt by what was supposed to be people that knew them, this thing cold start's and idles perfect, and rev's with no stumble's or issues but has what I would call a surge under load, the previous two owner's both said they rebuilt the carb and still had the same issue as me, so I think the carb has issues,,,Doc I will get you a carb number in the morning, but as far as I know it is origional to the motorhome, and also it has a set of headers and dual's so no heat riser.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967945
04/06/11 09:30 PM
04/06/11 09:30 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
hey on the bright side,,,I did get the gas guage fixed today,,,and you won't in your wildest dream's guess what was wrong.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967946
04/06/11 10:02 PM
04/06/11 10:02 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
You were missing the ground strap on the fuel line at the
gas tank?
If you are going to make changes and you don't have to
worry too much about smog stuff go with a Edelbrock Performer
intake and carb.
Phil Saran Parker, Colorado
Re: Motorhome 440,,carb@intake,,what choice's [Re: Phil Saran] #967947
04/06/11 10:23 PM
04/06/11 10:23 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
actually,,,,,just the opposite, there was a wierd looking bracket laying on top of the tank across the sending unit post and grounding it out, I was in process of taking the tank out to put in a new sending unit and was investigating what I needed to do to get it out and noticed this bracket just lsying there on top of the tank so I took it off and tried the guage for the heck of it,,,,,and it worked.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967948
04/06/11 10:36 PM
04/06/11 10:36 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
d-man ... it sounds like there is an issue on the primary side of the carb ...with surging. PROBABLY the wrong size rods in it.
I would suggest getting a spark plug reading at diff stages of running ...or BETTER YET .. put a wide-band 02 on it.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dOoC] #967949
04/06/11 10:41 PM
04/06/11 10:41 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
don't know anybody that has a wide band,,,is there any good reference book's that would tell me what I should have in it,,,,,,,guess I should of bought that $20.00 swap meet thermo after all.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967950
04/06/11 11:15 PM
04/06/11 11:15 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I don't have a wide-band yet either ... but I am going to get one.
The surging and poor mpg really don't go together(surging is lean - poor mpg is rich) ...uNless the carb tuning is totally messed up. At what speed is the surging taking place ?
Get a normal speed and high-speed read on the plugs for now. And you can ALWAY do better on the intake manifold.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967951
04/06/11 11:24 PM
04/06/11 11:24 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
I'd make sure you don't have a fuel delivery problem before you start replacing carbs & manifolds. If the previous owners experienced the same sort of problems it may be as simple as a plugged fuel tank vent. Remove or loosen the gas cap and see if that helps. I'm sure you checked the fuel filter and pump already
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Motorhome 440,,carb@intake,,what choice's [Re: U code RR] #967952
04/06/11 11:33 PM
04/06/11 11:33 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Fuel delivery ? ..possible .. but that would not just go-away with getting off the throttle like a WOT miss would be.
NOT a bad idea to check this with an actual gauge ...
Re: Motorhome 440,,carb@intake,,what choice's [Re: dOoC] #967953
04/06/11 11:42 PM
04/06/11 11:42 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
all new filters and new fuel pump, checked for kink's and smashed lines too.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967954
04/06/11 11:45 PM
04/06/11 11:45 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
HOW did the filters look? ... metal ones ? ....did you pull em apart?
Re: Motorhome 440,,carb@intake,,what choice's [Re: dOoC] #967955
04/06/11 11:59 PM
04/06/11 11:59 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
one at the carb was steel, small amount of verry verry fine silt came out, each tank has a clear chrysler type inline and they looked good like they had just been changed. but I changed them anyway.
Re: Motorhome 440,,carb@intake,,what choice's [Re: dartman366] #967956
04/07/11 12:12 AM
04/07/11 12:12 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
How many tanks do you have ? .... the best-bet is to put one of those TRACTOR GLASS FILTERS on first ... then run it through one of the clear ones.
You can get a bunch of junk in those tanks. How large are yours?
Re: Motorhome 440,,carb@intake,,what choice's [Re: dOoC] #967957
04/07/11 12:26 AM
04/07/11 12:26 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
40 gal main, 17 reserve
