Re: Rocker arm shafts and aluminum heads
[Re: 1970RT]
#967350
04/05/11 11:08 PM
04/05/11 11:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
1 yes you can use stock rocker gear 2 depends on what roller rockers they are
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: GomangoCuda]
#967355
04/06/11 05:54 PM
04/06/11 05:54 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Trust me, you do not want to put needlebearing rockers on chromed shafts.
Seems strange that the Harlan Sharp shafts are hard chromed then !!!
[Re: Stanton]
#967356
04/06/11 06:25 PM
04/06/11 06:25 PM
Posts: 4,767 Moved to N.E. Tennessee
GomangoCuda
Their website says "specially heat treated, heavy wall, rocker shafts." No mension of hard chrome.
http://www.harlandsharp.com/bb_mopar.htm
Here is what Dvorak says about shafts for H.S. rockers http://www.dvorakmachine.com/rockershafts.shtml
Racerbrown, T&D and Jessel don't use chromed shafts either with their needlebearing trunion rockers.
[Re: 1970RT]
#967357
04/06/11 07:18 PM
04/06/11 07:18 PM
Posts: 757 Toronto, Ont, Canada
boydsdodge
Don't forget to set up your valve to rocker geometry. Also you my need new hold down bolts, and push rods. I have had to raise and lower the shafts on Edelbrocks on different builds to get the rockers centered. P.S. They are not bolt on.
