stroker taredown..q's
#967319
04/05/11 09:48 PM
04/05/11 09:48 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
What is a offset ground crank?I have a 451 that im putting back together from a failed lifter..and where they turned down the rod journals it goes straight across throw to throw not beveled at the edges is that normal for a turned down crank?The rods have been rubbing the edges of the counter weights slightly and i am unsure if this is right..and the rods gap.030 between..oil pressure was 80psi Is this a 440 crank or 400 crank..I am new to this stroker engines buisness and am having to learn on the fly here. Also why do some call it a 452 as well.My crank has that wrote on one of the counter weights with a sharpie. Mains are standard and rods journals turned .020. Basicaly need answers on the crank issues and love to have links to anything 451..Thanks so much.... ![](http://i30.photobucket.com/albums/c340/fairline/003-2.jpg)
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
Re: stroker taredown..q's
[Re: Kern Dog]
#967322
04/06/11 09:14 AM
04/06/11 09:14 AM
451 D*O*D*G*E
Hr up from KCK
Thanks guys..so with the 440 crank is my engine internally balanced now?Lot of balancing work done to this.Thanks again.
[Re: Kern Dog]
#967324
04/06/11 02:16 PM
04/06/11 02:16 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Great to hear you're going through the motor and doing this right.
Your crank being cut straight across as you have described is normally just fine, but if the rods are truly rubbing on the counterweights, that could be a problem, and would seem very odd. Are you sure you mean the counterweights and not just the journal arms? Pics would be useful here.
Your crank is a 440, or RB crank (could be a 413 or 426). 452 vs. 451 is just an overbore measurement. My motor is .040 over, and displaces 452 cubes. A .030 over 400 block makes 451 cubes. Same motor.
Offset grinding is hard to describe, one picture would make it clear. Immagine a cross section view of the cranks rod journal. If you were to grind the journal down to a smaller size, and take all of the removed material off of one side of the journal, you would move the centerline of the journal. Move it to the outside, and you've increased the cranks stroke.
