A-body driveshaft loop and frame connector recommend? #966664
04/05/11 10:08 AM
04/05/11 10:08 AM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Need to get driveshaft loop and frame connectors for the Cuda. Any recommendations? Google took me to US Tool, but I didn't see any reviews. Any suggestions would be great. Toyed with the idea of just building some, but so many other projects makes time a factor.
Re: A-body driveshaft loop and frame connector recommend? [Re: OA5599] #966665
04/05/11 10:16 AM
04/05/11 10:16 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
without a doubt call John @ U.S Car Tool he did my complete set up on my Duster. ( Sub-Frame Connectors/ Drive Shaft Loops / Roll Cage install/ leaf spring relocation) John is a top notch guy who does awesome work.
Re: A-body driveshaft loop and frame connector recommend? [Re: OA5599] #966666
04/05/11 08:33 PM
04/05/11 08:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Here's a set up built by Ron Silva.
Bolts to tabs on the frame connectors
Re: A-body driveshaft loop and frame connector recommend? [Re: RobX4406] #966667
04/05/11 09:55 PM
04/05/11 09:55 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
If you want to keep it simple, mine are 2"x3" steel about 3/16"
thick and the driveshaft loop is a $40 bolt in unit.
Phil Saran Parker, Colorado
Re: A-body driveshaft loop and frame connector recommend? [Re: OA5599] #966668
04/05/11 11:10 PM
04/05/11 11:10 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
They sell one that u bolt to your cross member,
Not home now, can't post pic of it, have on my
Car, easy install.
Re: A-body driveshaft loop and frame connector recommend? [Re: B1KILLER] #966669
04/05/11 11:16 PM
04/05/11 11:16 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
best ones are made by chassis guys,,that goes for frame connectors also,better stronger steel then the ones mopar sells
Re: A-body driveshaft loop and frame connector recommend? [Re: RobX4406] #966670
04/06/11 11:43 AM
04/06/11 11:43 AM
Centerville, MN
schwep Offline
schwep  Offline
Centerville, MN
Actually, that's my car and the loop I made from DOM tube and piece of SCH 120 or 160 pipe.
Very easy to build...
Re: A-body driveshaft loop and frame connector recommend? [Re: OA5599] #966671
04/06/11 12:30 PM
04/06/11 12:30 PM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
http://www.unlawfulracing.com/5.html
Take a look here, I have it on my RoadRunner and soon to be on my Duster.
Re: A-body driveshaft loop and frame connector recommend? [Re: schwep] #966672
04/06/11 01:02 PM
04/06/11 01:02 PM
RobX4406 Offline
RobX4406  Offline
Nice work on that...
I had that with some pictures of Ron's Valiant. Sorry for erring where credit was due!
Re: A-body driveshaft loop and frame connector recommend? [Re: RoadRnnr69] #966673
04/06/11 01:31 PM
04/06/11 01:31 PM
Champaign IL
LXguy Offline
LXguy  Offline
Champaign IL
The best subframes for A-bodies are made from square tubing. Looks like an Abody in your post, sorry if this is for a different car. The pics are of my '71 Dart.
You can do 2*3 square tubing but you have to cut the floor. I did 1.5*3 (I think) tubing and had to press against the pan just a little bit but no cutting. These are invisible from the side, you have to stick your head under to see them.
Here are some pics (sorry they're not the best)
EDIT: Don't seem to be able to get the [image] code to work, if a mod could help, I'd really appreciate it. - Thanks. Links should still work though.
Front: (torsion bar crossmember - need to relocate e-brake cable on driver side-I don't have one) You can see I didn't want to cut my speedo cable when I went to race trans-LOL)
http://s325.photobucket.com/albums/k381/smoberley/IMG_1286.jpg
http://s325.photobucket.com/albums/k381/smoberley/IMG_1287.jpg
Rear - I like how this totally encapsulates the rear subframe, it appears to reinforce the torque boxes pretty well.
http://s325.photobucket.com/albums/k381/smoberley/IMG_1285.jpg
You can see how far it goes over the rear subframe in this pic.
http://s325.photobucket.com/albums/k381/smoberley/IMG_1288.jpg
The car is much stiffer with these subframes in place, and I have a solid place to put the jackstands.
The Mopar units look like toys compared to these, and hang down lower.
The same buddy who welded these in for me also did a really nice loop that goes between the two subframes that's removable and everything (but you can still slide the DS in and out with the loop installed). he's a wizard. The loop he did is between 5 and ten pounds lighter than the bolt on deal that was there before.
Hope this helps
Steve
Re: A-body driveshaft loop and frame connector recommend? [Re: RoadRnnr69] #966674
04/06/11 01:50 PM
04/06/11 01:50 PM
Champaign IL
LXguy Offline
LXguy  Offline
Champaign IL
That's a really neat idea. How much does that cost?
1971 Dodge Dart Swinger 5.9 Magnum, built 904 ET 11.70 / 113 mph Want to swap a Magnum into your Mopar? www.magnumswap.com
Re: A-body driveshaft loop and frame connector recommend? [Re: LXguy] #966675
04/06/11 05:45 PM
04/06/11 05:45 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Here are some pics (sorry they're not the best)Any body see a problems with this set up? Looks pretty slick and stout to me, am i wrong?
Hope this helps
Steve
