Six Pack high idle after hit #966637
04/05/11 08:55 AM
04/05/11 08:55 AM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
What better place than here to find out what the problem is with my 440-six pack road runner. The car runs great at idle and with the pedal mashed. My problem is the idle runs 1000-1500 rpm higher than normal (900 rpm) after I make a pass, or hammer it on the street. I am running the stock set up with vacuum secondaries on a stock intake. Is the problem I'm describing what the electric selenoids are for on the original cars? Mine does not have them. Thanks, Tom
Re: Six Pack high idle after hit [Re: Tommy D] #966638
04/05/11 09:01 AM
04/05/11 09:01 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
When it idles high have you physically tried to close each carb? Maybe one is hanging up. Overtightening the bases can cause this. Sometimes my carbs fall off but they never bind.
Re: Six Pack high idle after hit [Re: scatpacktom] #966639
04/05/11 09:05 AM
04/05/11 09:05 AM
Tommy D Offline OP
Tommy D  Offline OP
Thanks Tom. I haven't checked the base tightness. Usually I notice it when I drive on the street. I'm probably due for some new gaskets under the carbs anyway. I'll give it a try. I have not physically gotten out to see if or where they are hanging up. It's usually idling soo high that if i were to put it into park or neutral...it would rev pretty high. What were the solenoids used for on the originals?
Re: Six Pack high idle after hit [Re: Tommy D] #966640
04/05/11 09:17 AM
04/05/11 09:17 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The solenoid was used to prevent run on "dieseling". The solenoid is energized with the key in the on position and shuts off(relaxes) when the key is shut off. When the screw is adjusted properly, the center carb throttle plate will shut after turning the car off and prevent run on.
But this is likely not your problem. If it's not a vacuum leak or some other adjsutment issue or hang up as Tom said, you may want to check that the outboard idle mixture screws are properly adjusted. Try 1/2-3/4 a turn from seated to start and work from there. I have corrected the problem you describe by trimming(adjusting) the outbaord idle mixture screws. These are very sensitive and just a 1/8-1/4 turn one way or the other can lead to various problems.
MB
Re: Six Pack high idle after hit [Re: Tommy D] #966641
04/05/11 10:15 AM
04/05/11 10:15 AM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
i have fixed this problem several times. when the problem shows up,force the end carbs one at a time shut. if it slows down the problem is more likley the alunimun base bore is out of round.the best way i know to fix it is to sand paper the spot where the blade rubs on the bore.it may take several attempts
Re: Six Pack high idle after hit [Re: Tommy D] #966642
04/06/11 06:13 PM
04/06/11 06:13 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Make sure the linkages for the end carbs are doing their jobs. They are supposed to close the end carbs when the center is at idle. If there is any slack in them they may not be fully shutting the end carbs. Disconnect the end carb linkages and manually force the carbs closed. Then set the center carb idle. Reinstall and adjust the end carb linkage rods so that they solidly close the end carb butterflies.
