'68 Dart sending unit.........
#966628
04/05/11 08:41 AM
04/05/11 08:41 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Who makes the best? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ........It seems like EVERY single one I've bought lately is a piece of crap ![](/ubbthreads/images/graemlins/flame.gif) ........fuel gauge doesn't work, the gauge pegs if grounded, and I've a run good ground from the body to the unit..... ![](/ubbthreads/images/graemlins/popcrn.gif)
If you can't handle the truth, you're living a lie.......
Re: '68 Dart sending unit.........
[Re: mikemee1331]
#966634
04/10/11 03:37 PM
04/10/11 03:37 PM
RapidRobert
I need a good 3/8 one also. W all the reported probs I am going to take my OE 5/16" one & solder in/swedge a 3/8 line which'll let me get the bottom of the line (the horizontle bend) parallel to the tank bottom & just off of the bottom (no sock). Plus I filter each 5 gallons of gas I put in & there's a surprising amt of crud coming right from the filtered gas station pump
[Re: Big Squeeze]
#966636
04/12/11 12:10 AM
04/12/11 12:10 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Well, I finally got around to putting some gas in my tank and I believe the unit I bought is going to be pretty close. I put 5 gallons in out of a can and it showed just a little over a quarter tank. I will be driving the car to a station tomorrow and adding more gas in increments just to see where it reads, I'll let you know. This is where I got mine. http://www.classiccarautoparts.com/about.html
