Re: How fast in 1/4 with single AFB style carb [Re: 9SecRoadRunner] #966616
04/07/11 06:08 PM
04/07/11 06:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
OK 9Second. sure one can do it. carry on. OP also never posted what build or his desired et.
Re: How fast in 1/4 with single AFB style carb [Re: Mr.Yuck] #966617
04/07/11 06:54 PM
04/07/11 06:54 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
just bustin your b@lls Yuck...I owed you a few from the other carter/eddy/holley posts..but its all in fun, I dont take it serious or offensive, nor do I mean it that way
You Thinking It's So Doesn't Make It a Fact
Re: How fast in 1/4 with single AFB style carb [Re: 9SecRoadRunner] #966618
04/07/11 07:00 PM
04/07/11 07:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
just bustin your [Email]b@lls[/Email] Yuck...I owed you a few from the other carter/eddy/holley posts..but its all in fun, I dont take it serious or offensive, nor do I mean it that way
I know, no worries. I don't mind. I have a buddy that flat refuses to use a holley. Drives me nuts. His bro gave him a 850DP to try he WON't put it on......I told him to put it on and if it didn't drop his et 3 tenths I'd buy him a case of beer.
Re: How fast in 1/4 with single AFB style carb [Re: Mr.Yuck] #966619
04/07/11 08:03 PM
04/07/11 08:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've run 6.90's in the 1/8th with a tweaked 440 AVS before in a 440 a body, that's roughly a low low 11. Went just as quick as a 4779 holley but more consistent in hot weather.
A lot of guys don't know how to tune avs/afb's, or holleys, Q-jets or Webers....but that's not the carb's fault.
I run an 800 thunder AVS on my 427" small block Cobra, works better and is more tractible around corners than any Holley I've ever run....quick tip, on anything much over 450 horse running an AVS, it's best to run a dual line to the carb because the main achilles heel of the AVS/AFB design is the float bowls are a bit small for sustained High RPM power fuel flow, a single feed relies on internal cross-over flow.
WIZE
In Car:
Re: How fast in 1/4 with single AFB style carb [Re: Mr.Yuck] #966620
04/07/11 08:05 PM
04/07/11 08:05 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
OK a hypothetical question and a honest answer. I'm sure with enough money you can do a lot, BUT, every joe out there with his 4000lb car ain't gonna get his car into the 10's with a single 4 barrel. How fast do you want to go = How much are you willing to spend.
Re: How fast in 1/4 with single AFB style carb [Re: 6PACMAC] #966621
04/08/11 11:36 PM
04/08/11 11:36 PM
IL.USA
tatrwedge Offline
tatrwedge  Offline
IL.USA
We have two Max Wedge cars a 1963 Plymouth the best last year 8.65 and a 1964 Plymouth wagon the best 9.15 with two AFB 800's.They both ran this at Bowling Green last year.
