Cal Tracs #966424
04/04/11 11:48 PM
04/04/11 11:48 PM
Kane Co.
Longo Racing Offline OP
Kane Co.
what is the rule of thumb on setting the cal track system. I have a 10.5 tire and a mono leaf spring was suggested. I heard that an 1/8" off the leaf spring. Suggestions please. And also there are three hole settings also and how do i know which one to set on. Thank you for the input usterWork
Re: Cal Tracs [Re: Longo Racing] #966425
04/04/11 11:53 PM
04/04/11 11:53 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Calvert Racing has a customer service dept that is second to none. Give them a call.
Re: Cal Tracs [Re: BobR] #966426
04/05/11 07:40 PM
04/05/11 07:40 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
John Calvert has taken the time to talk to me even when I wasn't buying anything. Good guy.
Re: Cal Tracs [Re: topside] #966427
04/05/11 07:44 PM
04/05/11 07:44 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Soft inital hit - lower hole, zero preload
Harder initial hit - lower hole, preloaded
Even Harder initial hit - upper hole zero preload
Hardest initial hit - upper hole with preload
another one i found....
CAL-TRAC SETTINGS
Top hole – Hardest Hit
Bottom hole – Softer Hit, moves IC forward
More Pre-load, Softer Hit
Less Pre-load, air gap, harder hit
If car pulls to the right add a quarter turn of pre-load to the right bar and visa versa.
Set front shocks soft
Set rear shocks on #5, if car wants to porpoise go to 6 or 7 (harder).
If car spins, needs harder hit
Too much wheel stand…. Softer hit, restrict front travel
Re: Cal Tracs [Re: 69CHARGERMD] #966428
04/05/11 07:50 PM
04/05/11 07:50 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Information on how to set up your CalTracs suspension. ( Found this on another forum)
I thought I would make a POST FOR setup and issues that almost everyone has with Caltracs.
Also a place to start from for the first run/test pass along with how to adjust after you have a few passes. Start at the front and make sure the front control arms are not binding. This is one of the biggest issues. You can do this with after market bushings or control arms or just elbow grease. The control arms should fall on their own without having to push them down. The front springs need to be of a drag style that will give you the best weight transfer you can and MUST HAVE AT LEAST 5" OF UPWARD TRAVEL IN THE FRONT END. Shocks should be of a good drag style. I use the CalTracs shocks and there are great adjustable shocks for big wheelstanding cars. After doing all the above, SET THE SHOCKS AT FULL LOOSE FOR THE FIRST FEW RUNS. FOR THE REAR, same thing binding is the number 1 issue most the time it's in the shackels and the front leaf spring mounting bolt. Every car I see the bolts are over tightened. You should be able to push the rear down 5-6" easy without the shock or Caltrac mounted. Lube all bushings well and don't over tighen. Make sure theres no binding, any adjustment later will work. I always start in the upper hole and preload 1/4-1/2 depending on the appliciation. Shock settings ON REAR, I always start at full tight on extension. Know that the car is setup for a test pass; have someone video it.
The car will DO only a few THINGS now. IT WILL HOOK AND PULL A HUGE WHEELIE; IT WILL HOOK AND DO WANT YOU NEED; IT WILL HOOK AND pull left or right; IT WILL HOOK AND SPIN 20FT OUT; IT WILL KILL THE REAR TIRE BY HITTING IT WAY TOO HARD IF YOU HAVE DONE EVERYTHING UP TOP; I'M 95% SURE IT WILL ONLY DO ONE OF THESE THINGS.
IF IT HOOKS AND PULLS A HUGE WHEELIE THEN TIGHTEN THE FRONT SHOCKS. THIS SHOULD BE THE ONLY REASON TO TIGHTEN THE FRONT SHOCK. IF IT HOOKS AND PULLS TO THE RIGHT OR LEFT THEN PUT A LITTLE PRELOAD ON THE SIDE IT PULLS TO. IF IT HOOKS AND SPINS 20FT OUT START, LOOSEN THE EXTENSION ON THE REAR SHOCKS 1-2 CLICKS AT A TIME TILL IT HOOKS AND STAYS ON THE REAR TIRE. IF IT KILLS THE REAR TIRE, YOU NEED TO PUT THE BARS IN THE LOWER HOLE AND ADJUST THE SAME AS YOU WOULD IN THE UPPER HOLE. IF YOU HAVE LOWERED THE CAR A LOT, THERE ARE OTHER TRICKS TO DO BUT FOR THE MAJORITY OF THE CalTracs cars OUT THERE, this will be ALL YOU NEED
Re: Cal Tracs [Re: 69CHARGERMD] #966429
04/05/11 07:51 PM
04/05/11 07:51 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
CAL-TRAC SETTINGS
That pretty well covers it. Most High HP cars use the bottom hole because they are hitting it hard already .I'd say anyone with 900 + hp should always use the bottom hole with no gap on the spring.
Re: Cal Tracs [Re: RADAMX] #966430
04/05/11 09:34 PM
04/05/11 09:34 PM
near St Petersburg, FL
Lifsgrt Offline
Lifsgrt  Offline
What the heck Doug, you think you're a Doctor or something??
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Cal Tracs [Re: Lifsgrt] #966431
04/05/11 09:37 PM
04/05/11 09:37 PM
tboomer Offline
tboomer  Offline
Hmmm I think he is..
Re: Cal Tracs [Re: tboomer] #966432
04/05/11 11:17 PM
04/05/11 11:17 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Here is a picture from my residency training...lol
thanks guys,,,
Re: Cal Tracs [Re: 69CHARGERMD] #966433
04/05/11 11:50 PM
04/05/11 11:50 PM
tboomer Offline
tboomer  Offline
Dougy...You crack me up!!
Re: Cal Tracs [Re: 69CHARGERMD] #966434
04/06/11 12:57 AM
04/06/11 12:57 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
thanks guys,,,
Patient is not positioned in the bed properly!
Re: Cal Tracs [Re: 69CHARGERMD] #966435
04/06/11 01:16 AM
04/06/11 01:16 AM
Rapid City, SD
rickb67 Offline
rickb67  Offline
Rapid City, SD
Wow Doug that was awesome i am starting over on my setup thanks
Re: Cal Tracs [Re: 69CHARGERMD] #966436
04/06/11 01:21 AM
04/06/11 01:21 AM
Montgomery, Texas
O
OneRunSon Offline
OneRunSon  Offline
O
Montgomery, Texas
doug, thanks for the great info. can you give us the additional info / tricks for a lowered car.
Fred Vandiver
Re: Cal Tracs [Re: OneRunSon] #966437
04/06/11 01:51 AM
04/06/11 01:51 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
So I'm presuming that the Rancho 9000's set on 9 would be the stiffest on extension?? and 1 would be the softest which would let the rear rise too quickly...right???
First test and tune this weekend with the new Caltrac/Mono set up so gotta make sure we understand the shock settings.
Re: Cal Tracs [Re: OneRunSon] #966438
04/06/11 07:32 AM
04/06/11 07:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the rear of the car is lowered it will tend to
transfer the weight easier(less height the front has
to climb to get over the CG)... you would do 1 or 2
things soften the rear shock setting so the rear can
lift a bit more or tighten the front shocks and or
tie the front down with travel limiters
You are correct
Re: Cal Tracs [Re: MR_P_BODY] #966439
04/07/11 12:16 AM
04/07/11 12:16 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
thanks for this informed post ,what do you guys make of this ? with my homemade caltracks i have set up in my crapa is lower hole shocks on 1, 0 pre load is the only way this will hook 2inch lowed blocks ,split mono leaf ,calvert 90/10 my 60 ft are 1.6 ,will it work better with a small air gap , with pre load it spins.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Cal Tracs [Re: MR_P_BODY] #966440
04/07/11 01:37 AM
04/07/11 01:37 AM
Montgomery, Texas
O
OneRunSon Offline
OneRunSon  Offline
O
Montgomery, Texas
thanks mr. p i will add to my notes
Fred Vandiver
Re: Cal Tracs [Re: 69CHARGERMD] #966441
04/07/11 07:32 AM
04/07/11 07:32 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
how does being on the bottom hole on the caltracs change IC ?
Mopar Performance
Re: Cal Tracs [Re: moparniac] #966442
04/07/11 07:53 AM
04/07/11 07:53 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Calling Doctor Howard, Doctor Fine, Doctor Howard... Calling Doctor Howard, Doctor Fine, Doctor Howard!
This post is available in double vision where drunk.
Re: Cal Tracs [Re: moparniac] #966443
04/07/11 08:27 AM
04/07/11 08:27 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The bar is lower(more level) and moves the intersection point futher forward.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
