help with plugs and autolite "X" plugs
#966347
04/04/11 10:50 PM
04/04/11 10:50 PM
Posts: 111 Eldridge, IA
HR5058
Eldridge, IA
Looking for advice on plugs. Engine is 418 small block, aluminum older W-2 heads (valve angle is 14 degrees), 12.7 compression, 950 Quick Fuel carb, 4:56 gears with Powerglide, 5800 TCI convertor with Pro Brake, 3550 lbs with me in it. Ran 9:90's @133 mph last year with NGK R5671A-8.
Autolite says the equivlant to the NGK is the AR3934. But I see they make the "X" model that they state "sports a specially machined four-corner firing surface gap style instead of the normal single electrode. Specs. are 5/8" hex, 3/4" reach, 14mm thread, nickel plated shell, gasket seat, non-resistor."
What are your suggestions and anyone use the "X" model?
Thanks everyone,
Chuck
Re: help with plugs and autolite "X" plugs
[Re: HR5058]
#966349
04/05/11 01:56 AM
04/05/11 01:56 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Thanks everyone,
Chuck
i normally use the AR3934 but this season i used the X plug. it worked very well, just didn't need to gap it. the only drawback was it was hard to read the plug between the X but other than that they were great. i'm getting a carton of them for next season.
[Re: SB412DUSTER]
#966352
04/05/11 02:03 PM
04/05/11 02:03 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
What is the autolite equivlant to a -10? AR3932?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#966354
04/05/11 03:51 PM
04/05/11 03:51 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Yes. And it is a standard tip as apposed to a projected tip.
