Re: nhra rule for hose at fuel pump to carb
[Re: 74fldart]
#965283
04/03/11 06:12 PM
04/03/11 06:12 PM
I believe you can't hve more than 12'inches of rubber fuel line as per NHRA rules.
#965285
04/03/11 07:16 PM
04/03/11 07:16 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Flexible fuel line..........12 " max. But they do not consider braided to be flexible. I am not sure what the ruling would be for push lock .........the braiding is internal on this stuff. I'm pretty sure it depends on just how much the company which manufactures the line in question spends with them via contingency , event sponsorship and etc.
[Re: tubtar]
#965286
04/03/11 09:12 PM
04/03/11 09:12 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Pushlock hose is legal in any length.
[Re: Crizila]
#965288
04/04/11 12:48 AM
04/04/11 12:48 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Except where it passes by the bellhousing area where it has to be steel or steel breaded line.
It's still legal...it just needs to be protected by 1/8" thick steel tubing in the bellhousing area.
