Rear end job #965226
04/03/11 02:58 PM
04/03/11 02:58 PM
Dallas, Texas
71440_CYACOP Offline OP
Dallas, Texas
I'm looking to redo my rear end in my 1971 Roadrunner. It has 3.55 gears right now, but I'm wanting to swap it for a 2.76 or a 2.94 gear. I was wondering what gaskets would I need to replace and if I should replace the bearings as well. I'm only 19 years old and yall's help would be much appreciated.
Thanks, DJ
Re: Rear end job [Re: 71440_CYACOP] #965227
04/03/11 03:05 PM
04/03/11 03:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm not touching this with a 10 foot pole! i will tell you folks will need to know what type of 'rear end' you have!
Re: Rear end job [Re: 71440_CYACOP] #965228
04/03/11 05:17 PM
04/03/11 05:17 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
I would just leave the 3.55s in, unless you were looking to improve MPGs. If I were doing a gear swap (Actually I am right now!), I would replace all the gaskets and bearings for peace of mind. Right now I'm debating on the axle shaft bearings, seeing as I don't have the special tool the service manual says to use.
But really, you'll need to make sure you get your pinion depth, pinion bearing preload, ring gear run out and your ring & pinion backlash set to specs, then you're golden.
Re: Rear end job [Re: BEINGmeISaCRIME] #965229
04/03/11 06:44 PM
04/03/11 06:44 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
if it's an 8 3/4 rear,you should have no problem coming up with a 2.76 geared chunk for cheap.
