Scat small-block stroker radius crank-which bearings? #96501
07/29/08 01:32 AM
07/29/08 01:32 AM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
We are building a 360 magnum with a scat 4.00 inch stroker crank. The crank has a good size radius on the mains and I am wondering what brand or type of bearings are best to use ??
Re: Scat small-block stroker radius crank-which bearings? [Re: cudasam] #96502
07/29/08 07:24 AM
07/29/08 07:24 AM
i used clevite 77
Re: Scat small-block stroker radius crank-which bearings? #96503
07/29/08 07:36 AM
07/29/08 07:36 AM
the house on the left.
cogen80 Offline
cogen80  Offline
my scat kit came with clevilite 77 bearings. part # MS-1051p , its a 408 LA motor kit.
Re: Scat small-block stroker radius crank-which bearings? [Re: cudasam] #96504
07/31/08 01:51 AM
07/31/08 01:51 AM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
Thanks,guys.
Re: Scat small-block stroker radius crank-which bearings? [Re: cudasam] #96505
07/31/08 07:49 AM
07/31/08 07:49 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I use the clevite 77 H bearings on mine. I have the MP stroker crank but I believe that the radius is the same on them.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Scat small-block stroker radius crank-which bearings? [Re: StandOnIt] #96506
07/31/08 07:53 AM
07/31/08 07:53 AM
make sure you balance it. I got a balanced kit from Scat and it turns out, they dont actually weigh or match the pistons or rods. my machinist had to remove weight from 7 of the 8 pistons as well and change the weights of 7 of the 8 big AND small rod ends. the crank required 2 more holes to balance it out at the end of the ordeal. I hear this is common
