Re: race car wiring ?????
[Re: 67mprfan]
#964916
04/03/11 12:08 AM
04/03/11 12:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
hey guys I am getting ready to rewire my car, not sure what size wire to use 12,14, gauge for stuff like electric fuel pumps and electric water pump and fan.....THANKS IN ADVANCE
Well it makes a difference... some things draw HEAVY amps(some fans draw as much as 40 amps)... will you be using relays on the stuff
[Re: MR_P_BODY]
#964917
04/03/11 12:22 AM
04/03/11 12:22 AM
Posts: 1,030 ohio
67mprfan
ohio
hey mike didn't really think about relays the switch panel i have uses fuses but now i need to give that some thought..btw none is in the car now ......THANKS
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Sport440]
#964925
04/03/11 11:52 AM
04/03/11 11:52 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Is your battery in the trunk? Are you going to run an alternator? If so how many amps will it be sending 15' or so to the batt.? I think I use a 4 ga. wire for my alt. to batt. in trunk. 100 amps could melt a 10 ga. wire 15' long. There are sites or books that tell you what gauge wire for how many amps going what length. Don
[Re: 67mprfan]
#964926
04/03/11 12:08 PM
04/03/11 12:08 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
should I use relays with the arc switch panel
YES
Here is a chart to give you a better idea on what wires to use where. The "length" referred to is a total of both the hot and ground wires to the item.
Scotty
[Re: 67mprfan]
#964928
04/04/11 08:17 AM
04/04/11 08:17 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I just rewired my 4th car. Put in the ARC 8000R touch panel. It comes with a relay board that plugs in to the switch panel. Absolutely love it.
Besides the heavy current users (starter, battery, etc.) I run everything in 14 gauge mtw wire.
Why does divorce cost so much?
Because it is worth it!!!!!
