Installing 727 tranny onto engine - question
#964739
04/02/11 09:37 PM
04/02/11 09:37 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
The FSM on my '65 Satellite w/727 says to coat the crankshaft "pocket" with bearing grease where the torque converter's center hub sits when the engine and tranny are mated together. I forgot to do this, but could go back and do it. Does it matter? What's the purpose? There wasn't any grease in there when I pulled the tranny off, but I recall seeing streaks of the old stuff on the flexplate. Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Installing 727 tranny onto engine - question
[Re: dOc …]
#964742
04/02/11 10:01 PM
04/02/11 10:01 PM
67SATisfaction
Albany, NY
Thanks guys,
I've already bolted them together just not torqued yet (I only noticed the grease thing when I double checked the FSM procedure).
Doc, I think you mean the two stud kinda things that fit into the holes on the bellhousing? Yep, everything lines up -TC sits right good and I've got the one flexplate hole lined up opposite the TC drain plug (like the FSM says).
-Art
[Re: dOc …]
#964744
04/02/11 10:20 PM
04/02/11 10:20 PM
67SATisfaction
Albany, NY
Thanks, that takes care of it.!
