Pushrods for Crane roller rockers? Where to get'em #964732
04/02/11 09:14 PM
04/02/11 09:14 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Well, found a bent pushrod today. I thought Crane went out of business. Anybody make pushrods that are compatible with the Crane rollers? These are in a 440 which used "stock length" pushrods, no decking of heads or block. Thanks in advance.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Pushrods for Crane roller rockers? Where to get'em [Re: RTDaddy] #964733
04/02/11 09:29 PM
04/02/11 09:29 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Summit. hughes, Jeggs, just about any one as long as you get the push rod meant for hyd. lifters (if that is what you have) and ajustable rockers. Push rods for solid lifts would be way too long. If you have a bent push rod it may be that that is what you have now, or you may have coil bind. Did you use valve springs compatible with the cam? did you make sure that the valve stem retainer have at let .060 clearance at full valve lift from the guide/seal surface. Did you make sure that the springs have at least .060 travel to bind at full valve lift?
Re: Pushrods for Crane roller rockers? Where to get'em [Re: MoparforLife] #964734
04/02/11 09:38 PM
04/02/11 09:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the absolute best pushrods come from "Smith Bros" in Burns Or.. great prices too.
I am truckless..
Re: Pushrods for Crane roller rockers? Where to get'em [Re: RTDaddy] #964735
04/03/11 10:44 AM
04/03/11 10:44 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
You can call the Crane Cams tech line at 866-388-5120. Very much in business. Regards, Chase
