You dont need an SRT, or buy anything to add to you car to get it to do a good burnout. There is a little trick called the "key trick".
What this means is while going at least 10 mph, turn and hold the key like you are trying to start the car. Dont worry, the starter wont engage. Hold the key until you see the esp light and the bas light come on, then release the key. This completely disables the traction control and the auto braking system. It only works until you turn off the car, then everything resets.
After you do this, burn away!
