Re: does rear end height affect alignment?
[Re: mickm]
#964591
04/02/11 05:55 PM
04/02/11 05:55 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
In theory, yes. But the change you're talking about is so small as to be negligible. If toe and camber are zero, ride height would have no effect. An increase in rear height would have the effect of a small decrease in positive caster, or small increase in negative caster. If camber is slightly negative, increase in rear height would have the effect of increasing toe-in. (Think of an extreme example of car standing on it's nose.) Since you'll probably be going for max caster, with toe and camber to some values that you'll specify to the tech, I wouldn't worry about it. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Sixpak]
#964594
04/02/11 08:50 PM
04/02/11 08:50 PM
RapidRobert
set your weight in barbells on the pass seat & when you drive it on the rack pull em over to the dr seat b 4 you exit EDIT I would set the ride height ahead of time to the height that you prefer/looks good in the wheel wells (have car level/tires aired correct/half tank of gas and the weights in dr seat). If not, good possibility he will set it too low damhik. Jounce it after each of your adjustments & let it settle till you get it where you want it and the ride height has to b set b 4 the caster/camber and it'll function perfectly wherever YOU set it at (within reason) and inform him not to change it
[Re: GTXX]
#964597
04/03/11 07:57 AM
04/03/11 07:57 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I agree that small of a change wont affect it very much.As for using the factory specs unless you run bias tires toss them out the window.Radials need positive caster and about 1/2 degree camber.Rocky
Chrysler Firepower
[Re: therocks]
#964598
04/03/11 07:50 PM
04/03/11 07:50 PM
Posts: 587 minot north dakota
ledft79
minot north dakota
For every 1 degree your frame angle goes up in the rear, you loose 1 degree of positive caster. Also the extra weight transferred to the front of the car [from the rear being lifted] will also change the camber and toe some, not a lot. As far as will it need aligned, if it handles ok, then tire wear is your only question. Most old cars, the tires rot off before they wear off. If you only put 1 or 2000 miles or so on a year, and it handles good, you can probably get by without aligning it. Most places will align for $100 or so. That is pretty affordable for most of us that have these old cars. If your rear end is high, don't expect to get any positive caster.
DRIVE EM, DONT HIDE EM.
