Re: is cruise not always cruise?
[Re: mickm]
#964566
04/02/11 10:33 PM
04/02/11 10:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I assume you have a carb?
"cruise" is generally determined by vacuum level not rpm.
[Re: mickm]
#964569
04/03/11 03:44 AM
04/03/11 03:44 AM
Posts: 43,349 Bend,OR USA
Cab_Burge
Real light throttle in steady state(constant RPM) cruise the higher the AFR the cleaner the motor will run. I like to see 14.2 to 15.3 at light throttle cruise with my six paks and single four barrel motors at or above 2000 RPM Is this a street hemi 2x4 stock intake or a tunnel ram 2x4 or single plane 2x4 intake? It makes a difference Also are you using a dual wide ban with sensors in both sides or a single sensor on one side?If single have you switch it form one side to the other an if so does it read the same on both sides or different?
[Re: Cab_Burge]
#964572
04/03/11 01:46 PM
04/03/11 01:46 PM
Posts: 4,179 California
mickm
California
it is the stage V manifold, with 2X4 edelbrocks.
unfortunately i only have a bung in one side, time to put one in the other methinks. sounds like a good idea to get a better reading.
[Re: Supercuda]
#964573
04/03/11 01:49 PM
04/03/11 01:49 PM
mickm
California
idle is a little rich, in the 13's. i could take care of that. i wasn't aware that the idle circuit had that much influence on the cruise circuit. i thought that once into cruise it was pretty much off the idle circuit. and yes, even though i know that, i didn't take into account that vacuum is a function of load. i will play with the idle circuit a bit and see what that does. thanks for the suggestions...
