Surface Primer?(With a Pic.) #963818
04/01/11 03:32 PM
04/01/11 03:32 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I sprayed surface primer last year just b4 winter and i thought that it sprayed fairly well 4 the first time.Well i was wrong When the primer dry it has that alligator texture to it and wondering what procedure would be best to eliminate this rough texture.Can i just sand with a say (320)then final sand with a (400) r what will b the best way of tackling this i thought I'll ask here on Mo parts b4 i go any farther.Any help would b greatly appreciated.Thaxx
Re: Surface Primer? [Re: racerx] #963819
04/01/11 03:36 PM
04/01/11 03:36 PM
Kentucky
Sasquatch4406 Offline
Kentucky
id say youd have to get rid of it. strip it off with 80 grit
Re: Surface Primer? [Re: racerx] #963820
04/01/11 03:37 PM
04/01/11 03:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Surfacing primer is meant to be block sanded... It's better if it lays out smooth but your gonna be sanding anyway...
Re: Surface Primer? [Re: 1_WILD_RT] #963821
04/01/11 04:36 PM
04/01/11 04:36 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxx's 1 wild r/t that's what I'm thinking I'm trying 2 get photo bucket 2 host a pic but it's not happening but like said it laid down fairly well i think with no runs,just has that rough texture.
Re: Surface Primer? [Re: racerx] #963822
04/07/11 12:48 PM
04/07/11 12:48 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
? anyone has ever prep b4, using a DA sander B4 top coating.Or can it be done? Thaxxx
Re: Surface Primer? [Re: racerx] #963823
04/07/11 01:52 PM
04/07/11 01:52 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
A DA sander will make the surface smooth, but it won't level it. You need to block sand. There is no free lunch with body work.
Re: Surface Primer? [Re: Aero426] #963824
04/07/11 03:00 PM
04/07/11 03:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup, I'd start with 120-150 dry and get it level again.
You used either the wrong reducer for the temp or the wrong proporation when you mixed it. Got to have a pretty good tip size to spray surfacer, 1.8-2.2 or so.
Re: Surface Primer? [Re: Challenger 1] #963825
04/07/11 04:57 PM
04/07/11 04:57 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxx's That's what i was thinking to use a DA to smooth it then follow up with a blocking of #400.
Re: Surface Primer? [Re: racerx] #963826
04/07/11 05:40 PM
04/07/11 05:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
Wrong... You will never get it right that way.
Re: Surface Primer? [Re: Challenger 1] #963827
04/07/11 07:41 PM
04/07/11 07:41 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
So what will u recommend?your help is greatly appreciated
Re: Surface Primer? [Re: racerx] #963828
04/07/11 07:49 PM
04/07/11 07:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
To get the body straight your'll need to block it with something courser than 400. I'd block it down dry with some 150-220 and then reprime and see where I'm at before wet sanding with 320-400.
A DA will make a mess unless your really good with it or just want to strip it then whip out the DA.
Re: Surface Primer? [Re: Challenger 1] #963829
04/07/11 08:44 PM
04/07/11 08:44 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Finally got photobucket to cooperate here's a pic so u can possibly see what's going on
Re: Surface Primer? [Re: racerx] #963830
04/07/11 09:10 PM
04/07/11 09:10 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Do you want quick, or done right? Gotta block it.
Re: Surface Primer? [Re: racerx] #963831
04/07/11 09:10 PM
04/07/11 09:10 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
It looks normal to me. Take a black spray bomb and mist a light guide coat on. Then start block sanding grasshopper. On your first prime coats, you are going to sand most of it off anyway.
Re: Surface Primer? [Re: Aero426] #963832
04/07/11 09:13 PM
04/07/11 09:13 PM
Under My Car
Mopar_Country Offline
Under My Car
I was told the same thing by a body man with 40 years of it under his belt. Works good.
Re: Surface Primer? [Re: Aero426] #963833
04/07/11 09:14 PM
04/07/11 09:14 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Spray it with guide coat and start blocking with 180.
Re: Surface Primer? [Re: AdamR] #963834
04/07/11 10:37 PM
04/07/11 10:37 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
^ Exactly,block it and use it as intended to fill the low spots and surface imperfections.Mix more surfacer and add some slow reducer to help the primer flow.It will give a smoother application when you spray.It will also be easier for you to sand with 360 to 500 grit before sealer or paint.final sandpaper grit is dependent on the type of paint to be applied.What brand and type of primer-surfacer are you using?Epoxy,2k urethane,or other?
RT
Re: Surface Primer? [Re: RTSrunner] #963835
04/07/11 10:48 PM
04/07/11 10:48 PM
crlush Offline
crlush  Offline
looks like primer to me, start blocking with 180.
Re: Surface Primer? [Re: RTSrunner] #963836
04/07/11 10:54 PM
04/07/11 10:54 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I'm useing that Summit 2k urethane primer surfacer. Thaxx
A few have mention to block with 180.Would that course of a grit be to rough?Or do i need to follow up with say 320-400.Sorry 4 so many ?,but I'm taking time off work to hopefully get this finish all uall help is greatly appreciated
Re: Surface Primer? [Re: racerx] #963837
04/07/11 11:11 PM
04/07/11 11:11 PM
Cincinnati, Ohio
Cincinnati, Ohio
Nope, it(sandpaper) has to be ruff so it cut's and get's the panel straight, it's the only way. If you go to fine right away, it will never get flat and will be all wavey.
Block sand in a X shape and do it for hours, many. Get your self some durablocks and get busy. I have also used homemade blocks to sand with. It don't have to be Durablocks, but they work so nice.
Guide coat is a must also. Try it, your'll see.
here they are with a heavy guide coat before blocking.
210 hours worth, to this.
