Alternator problem? #963712
04/01/11 01:30 PM
04/01/11 01:30 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
I went out today to find 2 dead batteries. There is nothing on in the racecar. Is there a way that a Toyota alternator can discharge 2 deep cycle marine batteries in 48 hours?
Re: Alternator problem? [Re: marvo451] #963713
04/01/11 04:53 PM
04/01/11 04:53 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I am planning on running the alt you refer to (Denso 60amp, toyota forefunne set up ? )
I have seen this quoted,,,,,
"300mA or More of Current Drawn When Motor is Off"
Re: Alternator problem? [Re: marvo451] #963714
04/01/11 05:13 PM
04/01/11 05:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you have the master switch off... if you did, either
they werent charged up OR you have 1 or both bad
batteries(possible shorted cell) also being that you
run a alt you should run a NON deep cycle type battery
Re: Alternator problem? [Re: MR_P_BODY] #963715
04/01/11 05:24 PM
04/01/11 05:24 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
They were fully charged, but I forgot to throw the disconnect. I had 2 new deep cycles before I added the alternator. They are still less that one year old.
Re: Alternator problem? [Re: marvo451] #963716
04/01/11 05:36 PM
04/01/11 05:36 PM
Az
Crizila Offline
Crizila  Offline
Az
A 1/3rd of an amp is a pretty good draw, but the only way to know for sure is to put an amp meter on it once the battery's are charged up again.
Fastest 300
Re: Alternator problem? [Re: Crizila] #963717
04/01/11 06:05 PM
04/01/11 06:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... pull the pos cable and put the amp gauge between
the post and the cable to check it(engine off)...
but to kill 2 batteries in 48 hours you will have a
pretty good draw
Re: Alternator problem? [Re: MR_P_BODY] #963718
04/02/11 06:16 PM
04/02/11 06:16 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
I took the charge wire off of the battery(wire to alternator) and left the battery disconnect on overnight. No loss in batttery voltage overnight. So, it must have something to do with my alternator.
Re: Alternator problem? [Re: marvo451] #963719
04/02/11 06:26 PM
04/02/11 06:26 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
hook up the output wire and see if the alt gets warm just sitting without running the engine, if so the internal reg may be bad
Re: Alternator problem? [Re: emarine01] #963720
04/03/11 08:57 AM
04/03/11 08:57 AM
pa
572charger Offline
572charger  Offline
pa
had that happen on my 1 wire alt badd internal reg new reg never did it again !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
