904 output shaft #963389
03/31/11 10:55 PM
03/31/11 10:55 PM
Under My Car
Mopar_Country Offline OP
Under My Car
When looking at the trans from the rear, which way does the output shaft turn in drive? CW or CCW
Re: 904 output shaft [Re: Mopar_Country] #963390
03/31/11 11:03 PM
03/31/11 11:03 PM
Iowa
Hey19 Offline
Hey19  Offline
Iowa
The motor turns clockwise from the front. This is counter clock wise looking at the rear. Trans is the same.
Re: 904 output shaft [Re: Mopar_Country] #963391
03/31/11 11:03 PM
03/31/11 11:03 PM
CCW
Re: 904 output shaft [Re: RapidRobert] #963392
03/31/11 11:04 PM
03/31/11 11:04 PM
Under My Car
Under My Car
Re: 904 output shaft [Re: RapidRobert] #963393
03/31/11 11:05 PM
03/31/11 11:05 PM
Iowa
Hey19 Offline
Hey19  Offline
Iowa
Wow 10:03 to a 10:03 post. I must have got a hole shot on you.
Re: 904 output shaft [Re: Hey19] #963394
03/31/11 11:08 PM
03/31/11 11:08 PM
Under My Car
Under My Car
Cut a better light fur sure.
Re: 904 output shaft [Re: Hey19] #963395
03/31/11 11:10 PM
03/31/11 11:10 PM
yep better 60 footer and I was considering deleting mine
